CA tie rods
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=111497
Printed Date: 14 Sep 2025 at 8:41pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: CA tie rods
Posted By: Joe(OH)
Subject: CA tie rods
Date Posted: 05 Sep 2015 at 8:54am
Need to adjust my wide front out, but my tie rods are stuck. Took them off the tractor used heat and a bfh but can't get them to come apart. Anyone have any tricks to getting them apart? Or what are you guys using as replacement tie rods? Thanks!
------------- Life is simpler when you plow around the stump.
Posted By: DSeries4
Date Posted: 05 Sep 2015 at 8:56am
New tie rods are available on the aftermarket. Lots of heat and oil is needed to loosen up seized tie rods.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: wfmurray
Date Posted: 05 Sep 2015 at 12:00pm
Put penetrating oil on and let soak next use hammer (about one lb)and beat all over . The light beating will make the metal stretch and loosen up .It will take patance.It worked on my B and I had tied it to a tree and pulled it with D14.
Posted By: Sugarmaker
Date Posted: 05 Sep 2015 at 8:13pm
Yes lots of PB blaster, heat and I used a pipe wrench to get it to budge (turn) once it moves you got it! Then grind off all the marks and re assemble with some never seize on the stem. Regards, Chris
------------- D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Allis F-40 forklift, Allis CA, Allis D14, Ford Jubilee, Many IH Cub Cadets, 32 Ford Dump, 65 Comet.
Posted By: Joe(OH)
Date Posted: 05 Sep 2015 at 8:43pm
Got one to make a full turn, but it's still stuck! Got them soaking for now.
Posted By: Josh Day
Date Posted: 05 Sep 2015 at 9:14pm
50/50 mix of aceatone and ATF, soaked the wide front spindle tubes on a IH 560 with it for a day, came right apart. Or buy a new set lol.
------------- AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Posted By: ctbowles58
Date Posted: 05 Sep 2015 at 10:18pm
when you get them apart and cleaned up, put NEAVER-SEZE on them before you put them back together.
------------- 190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Date Posted: 06 Sep 2015 at 9:21am
Now that you mention it I think I had to use a 2 lb sledge at some point to get it to move out. Just try not to destroy the part your whacking on. I may have beat on the end that is under the tractor just in case the damage was going to be more apparent:) Yea these are a bugger. I was to cheap to buy an new set. In fact one was bent and I straightened it too. I think I even shortened the stems a little bit (couple inches). Regards, Chris
Posted By: Joe(OH)
Date Posted: 30 Oct 2015 at 7:58am
Had them soaking, still stuck. I'm thinking about just replacing them but everything I find needs the holes reamed out with a 7 degree taper. Are there any available that will fit with out modification?
