CA Restoration-remove water pump pulley |
Dale (Stonelick)
Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 186 |
Topic: CA Restoration-remove water pump pulleyPosted: 10 Jan 2020 at 1:21pm |
How is a fan belt pulley best removed from an old water pump? I have a new replacement water pump that didn't come with a new pulley. I tried a gear puller but was concerned about bending the old pulley. I have used a MAPP torch and have it sprayed down with penetrating oil.
If a new pulley if needed, who sells these? I couldn't find at Steiners, US Ag Parts, or Amazon.
Gerald J. - I looked in the on-line manual but it does not indicate how a rusty pulley can be removed. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 10 Jan 2020 at 1:25pm |
I gently tap around the edge perpendicular to the shaft while turning it. After you get it loose, you'l need to turn it a 1/4 turn to get the adjustment bolts to pass the hub.
Dale (Stonelick)
Posted: 11 Jan 2020 at 11:19am |
PaulB: Thanks. I kept torching, oiling and tapping and it finally came loose. After the 1/4 turn it was still hanging up, so I cut off the extended stove bolts and punched the heads in. The part cleaned up real nice with a brass wire wheel.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 11 Jan 2020 at 11:30am |
