CA distributor/governor oil supply line.
Shade Tree View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shade Tree Quote  Post ReplyReply Direct Link To This Post Topic: CA distributor/governor oil supply line.
    Posted: 02 Oct 2018 at 8:36pm
....I need to replace the oil line from the "T" at the head/rocker supply to the "T" at the Governor oil supply on my CA. It is a very small steel tubing with compression fittings on each end. I am hopping this is something I can buy already made up...or at least steer me to a supplier of the tubing and fittings.
DSeries4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 8:52pm
Napa.  Use tube benders to shape it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shade Tree Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 8:56pm
...what size is the tubing that runs to the governor oil supply fitting,.?
pumpkinman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 9:06pm
I think I have one  Will look tomarow in daylite will get
back to  you                  kent
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 10:12pm
Yea I would also go to NAPA store with the old parts and match up the connections. Compression type fitting. Probably 1/8 inch steel line? They might have the new flexible brake line also. Might be easier to form?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shade Tree Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 7:44am
...it appears mine rusted out...pretty strange, not much rust on the tractor and all the other small tubing lines are fine...it probably had  impurities in the steel at the point it rusted out.  Thanks for your attention.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 8:40am
1/8 inch compression.  same size as oil pressure gauge line
Edited by CAL(KS) - 03 Oct 2018 at 8:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shade Tree Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 8:43am
...thanks, going to town to find it.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 8:48am
My C had 1/8" copper line on it since I bought it in 1986. I replaced the ring in the compression fitting when I linked it many years ago. It was the same ad the sending line on a shallow well pump.
