CA distributor/governor oil supply line.
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=154493
Printed Date: 11 May 2025 at 8:25pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: CA distributor/governor oil supply line.
Posted By: Shade Tree
Subject: CA distributor/governor oil supply line.
Date Posted: 02 Oct 2018 at 8:36pm
....I need to replace the oil line from the "T" at the head/rocker
supply to the "T" at the Governor oil supply on my CA. It is a very
small steel tubing with compression fittings on each end. I am hopping
this is something I can buy already made up...or at least steer me to a
supplier of the tubing and fittings.
Posted By: DSeries4
Date Posted: 02 Oct 2018 at 8:52pm
Napa. Use tube benders to shape it.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Date Posted: 02 Oct 2018 at 8:56pm
...what size is the tubing that runs to the governor oil supply fitting,.?
Posted By: pumpkinman
Date Posted: 02 Oct 2018 at 9:06pm
I think I have one Will look tomarow in daylite will get back to you kent
Posted By: Sugarmaker
Date Posted: 02 Oct 2018 at 10:12pm
Yea I would also go to NAPA store with the old parts and match up the connections. Compression type fitting. Probably 1/8 inch steel line? They might have the new flexible brake line also. Might be easier to form? Regards, Chris
------------- D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Allis F-40 forklift, Allis CA, Allis D14, Ford Jubilee, Many IH Cub Cadets, 32 Ford Dump, 65 Comet.
Date Posted: 03 Oct 2018 at 7:44am
...it appears mine rusted out...pretty strange, not much rust on the tractor and all the other small tubing lines are fine...it probably had impurities in the steel at the point it rusted out. Thanks for your attention.
Posted By: CAL(KS)
Date Posted: 03 Oct 2018 at 8:40am
1/8 inch compression. same size as oil pressure gauge line
------------- Me -C,U,UC,WC,WD45,190XT,TL-12,145T,HD6G,HD16,HD20
Date Posted: 03 Oct 2018 at 8:43am
...thanks, going to town to find it.
Posted By: Dakota Dave
Date Posted: 03 Oct 2018 at 8:48am
My C had 1/8" copper line on it since I bought it in 1986. I replaced the ring in the compression fitting when I linked it many years ago. It was the same ad the sending line on a shallow well pump.
