brake drum |
Kiwi
Joined: 23 Jan 2018 Location: New zealand Points: 391 |
Topic: brake drumPosted: 21 Feb 2018 at 1:07am |
hi i am having trouble getting the brake drum off a B i have tried with a 3 leg puller but it will not move i have also soked it with wd40 anyone have some tips
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 21 Feb 2018 at 3:33am |
Heat might break it loose. Most of the time the drum is destroyed in trying to get it off and has to be replaced. A number of the suppliers that support this Forum have them available.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5189 |
Posted: 21 Feb 2018 at 6:08am |
WD40 is a useful product, but (IMHO) isn't a very good penetrant. There are several other products that are much better. I like Kroil best, but I also use PB Blaster and Liquid Wrench.
If you want to make your own penetrant, a 50/50 mix of automatic transmission fluid/acetone works very well. I have also used ATF/diesel fuel, but the acetone seems to work better.
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Posted: 21 Feb 2018 at 6:41am |
We used a heavy duty puller on the d15. Rods thread into the 2 threaded holes on the drums and there is a push bolt that pushes on the shaft.
CTuckerNWIL
Posted: 21 Feb 2018 at 7:28am |
Do NOT pull on the drum OD, only on the hub. If all you have is a "finger" puller, take a cut off wheel and make a few cuts on the hub so it breaks easier.
You can also remove the final drive and press the shaft out with a hydraulic press. I use WD40 to keep my garden hoe from rusting and to dry out a distributor cap if it gets wet inside. It's not a good penetrating fluid. Edited by CTuckerNWIL - 21 Feb 2018 at 7:30am |
Kiwi
Posted: 21 Feb 2018 at 1:30pm |
thanks all it looks like i need a better penetrant and more power as they say no matter what the question is the answer is more power
