|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Bill's '52 CA |
| Post Reply   | Page 12> |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Topic: Bill's '52 CA Posted: 18 Sep 2011 at 5:19pm |
   I'm trying to get my '52 CA up and running.  After that I want to continue to improve on it.  I'm fairly competent mechanically and have rebuild various types of different engines over the years.  Yet, I find myself in need of some help.
 Hope you guys & gals don't mind me starting a thread for my tractor project.  I figure I'd have to start a new thread everytime I have a question.  No point in that, so one thread to handle all my question when I'm stumped. Currently I'm battling an intermittent spark situation.  I'm getting spark about 1% of thetime.  When I do have spark the engine fires up and runs, then I loose spark right away.  Previous owner (poorly) installed a standard GM alternator and ran a 12 volt battery.  The ignition switch was replaced with a generic one.  The wiring is a mess so I unhooked everything and ran just the wires needed to get it running.  Once I get it running I'll refine the wiring.  Currently I have a Ford style stand alone solenoid.  Hot wire runs from the hot side of the solenoid to the 'batt' terminal on the ignition switch.  Have a wire running from the ignition switch 'ignition' terminal to the batt (+) terminal on the coil.  Have a wire running from the coil negative (-) terminal to the distributor.  Have a wire running from the 'start' terminal on the ignition switch to the terminal on the solenoid to close it and power the starter.  Both battery cables are new and of proper size.  The battery is a new 12 volt version.  The coil is a new 12 volt coil.  New spark plugs, wires, distriutor cap, rotor, points, and condensor. Using a basic circuit tester, I'm getting electricity everywhere I'm suppose to. So what am I overlooking?  I read that the CA ran the positive to the frame and the negative cable to the starter.  The previous owner wired it up with the negative to the frame and the positive to the starter.  I fail to see how this could be the problem, but could it?  Should I reverse the battery cables? It acts as if there is an intermittent  open circuit somewhere. There is a, for lack of a better term, stud inside the distributor that has a piece of spring steel that passes through it.  There is nothing hooked to it so I have no idea what it is for.  I can find nothing in the service manual that describes it.  What is it for and should I have something connected to it? I'm not running a resistor upstream of the distributor yet.  Could this be the problem? One thing I haven't checked yet is if it is in time.  It did run many years ago before sitting.  I just had the head off and had to install four new exhaust valves, and of course new gaskets. Sorry for the long post, but wanted to describe everything the best I could in hopes you guys can help me.  This thing has me stumped and I really need some help.  Thoughts on what I'm overlooking or doing wrong?? Thanks, Bill | |
     Bill Felten
| jccleav   Orange Level     Joined: 11 May 2011 Location: Indianola IA Points: 211 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 5:49pm |
   Negative ground should be correct with an after market alternator. Are you getting spark out of the distributor? There are only a few pieces to check. The coil, points, condenser, wires and plugs. I usually start at the plug then move to the distributor to eliminate the plug wire. This is guessing there is always power at the coil with the switch on. Hope this helps. | |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 6:12pm |
   Thanks for the post.  While cranking it does have voltage at the coil (+) terminal.  What I have not checked yet is if it is still getting voltage during the very brief periods it does fire off.
 I checked for spark by sticking a screwdriver in the end of a spark plug wire and holding it close to a ground (holding it by the big plastic handle).  While cranking there is no spark.  Then it'll get a little spark and when it does it takes right off...then no spark again. Anybody know what that other terminal or stud is for under the distributor cap?? | |
     Bill Felten
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 8:10pm |
   If the coil is original, the 12 volts could have fried it internally. When I changed my CA over to 12 V I didn't change the coil right away and it would run for a little bit and get hot and start missing. Maybe you could check the resistance of the coil and somebody could tell you if it is the right one. I wouldn't think about adding an external resistor when you can buy a new coil with the right resistance for under $20.
     http://www.ae-ta.com  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF | |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 10:04pm |
   Picked up a new 12 volt coil from O'Reillys.  I measured the ohms across it before I hooked it up.  While it measured a little lower then the numbers I found on the internet, it wasn't too far off (not that the numbers I found on the internet are from the coil athority).
 Thanks for the thought.  The new coil is behaving the same as the old coil.  Could the new coil be bad out of the box? How do I check the timing on this engine?  I see no clear timing mark on the crank pulley or a timing indicator as on a car engine. | |
     Bill Felten
| BennyLumpkin   Orange Level     Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 10:41pm |
   Do you have the points set up correctly?  Doesnt take much to get them to short out.
     Central PA Allis Express 1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 | |
| Brian Jasper co. Ia   Orange Level   Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Sep 2011 at 11:29pm |
| What kind of shape is the distributor shaft bushing in? If the shaft is wobbling around in a very loose bushing, it could be either not opening or closing the points. You can get a rebuilt dist pretty easily. I was told by an old A-C dealer that you can get by with a worn bushing by driving it out of the housing, cutting it in 2 equal halves and reversing them when putting them back in. It worked on my CA for several years. Did you also pull a piece of heavy uncoated paper through the points to clean any dirt or grease from them. It doesn't happen often, but it is possible to get bad new parts. I would expect the condenser to most likey be the one if you got a defective part. | |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 5:49am |
 Put them in new and gapped them according to what the repair manual calls for.  I have checked them and double checked them.  They are opening and closing completely.  Checked the face of them and they appear clean.  Using a basic circuit tester I checked for voltage on the negative side of the coil (-) when the points are closed and opened.  When they are open there is no current.  When the points are closed there is current at the coil (-), at the lug on the side of the distributor, and in the points.  At least that's how I'm remembering it today.  I checked yesterday and I've slept since then, albeit not much sleep.  I could be remembering it the wrong way around.  This is the correct behavior, right?? Couldn't be that the condensor is for a 6 volt system and I'm running 12, could it?  Given it's function, I like to think the voltage wouldn't matter to the condensor much, but I've never worked on a 6 volt system before, let alone one that has been converted.  I do know I bought the correct points & condensor for the tractor, so they are designed to work on 6 volts, not 12. Still want to know what that other lug is inside the distributor.  Anybody know?? | |
     Bill Felten
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 5:55am |
I have not yet pulled the distributor as I do not know how to time this engine properly.  The shaft doesn't show any excessive play while installed, but given the state of everything else on this little tractor I am sure the bushing is worn; to what extent I cannot say for sure.  I'll pull it and give it a closer look.  That and I'll price a replacment. If the condensor has failed, what behavior would you expect to see?  I've always replaced the condensor when replacing points as they are pretty cheap, but I've never experienced a failed condensor.  Would be great if this was the problem. | |
     Bill Felten
| allisorange   Silver Level     Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 7:02am |
|          I have had condenser no good out of the box and points that have been bad a short time after installing. Some of this stuff is made in China and not of much quality.                                                     John Carlson | |
| B26240   Orange Level   Joined: 21 Nov 2009 Location: mn Points: 3866 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 7:05am |
   I would try a differnt condenser also have you bypassed the ignition switch? run a wire direct from batt positive post to coil.
| SteveC(NS)   Orange Level   Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 11:12am |
   I,m curious about "There is a, for lack of a better term, stud inside the distributor that has a piece of spring steel that passes through it.  There is nothing hooked to it so I have no idea what it is for.
Is there anyway to take a pic of it so we could see if it might be part of the problem.
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 5:18pm |
 The stud with the spring steel is just that, a spring to hold the points closed. The cam on the distrib shaft opens them. The end of the spring should connect to the wire that goes through the side of the distributor back to the coil. | |
| jccleav   Orange Level     Joined: 11 May 2011 Location: Indianola IA Points: 211 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Sep 2011 at 7:19pm |
   Oreillys should have asked if it was a 12 volt or a 6 volt system. When you are checking the points do you see any spark when the points open? The condenser is nothing more then a capacitor that supplies the current for the spark plugs. It might say on the side if it is 12 or 6 volt. the same for the coil. | |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Sep 2011 at 6:16am |
 I'll see about getting a pic tonight when I get home and posting it up. Going to stop by NAPA on the way home (if I don't forget) and buy a condensor for a 12 volt engine.  I could be wrong, but I'm guessing just any 12 volt condensor will do??  Figure I'll buy one for an old Chevrolet, like my '69 Nova for example.  I'm sure the new condensor I installed is for the oringinal 6 volt system as I bought the points/condensor for the original ignition system. Thanks for all the input.  Got my fingers crossed it is the condensor, but some how that seems just too simple. Since the coil was asked about...I bought it new from O'Reillys and asked for a 12 volt coil since the previous owner had changed the system over.  Prev owner did a poor job of it, so improving upon it is the next step after getting it running. I was going to hook the coil to the battery, bypassing the ignition switch, but decided against it for the time being.  My fear is that if it does start, I'll be scrambling to shut it down should the engine start to run away from me.  I doubt this would or could happen, but my mind gets occupied with these types of thoughts.  The circuit tester shows power at the coil, but I didn't break out the multimeter to measure voltage.
 I'll get that pic and let you know if the new condensor makes a difference. | |
     Bill Felten
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Sep 2011 at 7:27am |
   Finally took some (poor) pics of the distributor and this strange (to me) item/post that is inside of it.  What is this thing?
     Bill Felten
| SteveC(NS)   Orange Level   Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Sep 2011 at 1:54pm |
My guess would be that it's an oiler for the 4 lobes of the distrib. but it seems to have lost it's felt?
| SteveC(NS)   Orange Level   Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Sep 2011 at 1:58pm |
There seems to be a lot of rust in there, could it be your points aren't making it to ground?
| Goose   Orange Level     Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Sep 2011 at 3:32pm |
   If I were you, I'd "hot" wire it to get it running, then start working backwards to eliminate what might be wrong, one step at a time.
 By hot wiring, I mean run a jumper wire from the positive side of the battery to the positive side of the ignition coil. It should run. Then run it for a while, even take it for a drive. If it still runs after a while, you know the problem is back a ways, perhaps in the switch or connections. But I wouldn't be too concerned about the charging system, which should have no bearing on the ignition system other than keeping the battery charged. | |
| wayneinwi.   Bronze Level     Joined: 06 Mar 2011 Location: So.Wi. Points: 11 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Sep 2011 at 10:52pm |
| I put new points in my G a few years ago,it started up but it always had a miss in it when running some times better or worse,tried al kinds of things with it but it did no good,so I decided to take out the new condenser and put the old one back in it and it ran perfect so some times they can be bad. | |
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Sep 2011 at 7:00pm |
   I have the wiring down to the bare minimum as it is now.  Still, it only occasionally sparks, but when it does it fires right off. The points seem to be grounding fine. I considered running a ground wire from the distrib hold down (still might), but the starter is grounding fine through the engine/torque tube, and the battery cables are new. I'll look into this some more. Would someone tell me more about the oiler. What does it oil? Is the felt available or can I use just any kind of felt? No mention of it in the service manual I have. Anyone have a diagram? Could this cause my no-start problem? So many questions. Please help. | |
     Bill Felten
| Wes (VA)   Orange Level   Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Sep 2011 at 9:48pm |
   Sounds like you could have some wires backward on the switch.    Leave everything together so that you can still use the starter, but eliminate the switch going to the ignition coil.  Use a jumper like others have said..I'd fasten it to the coil and leave the other end loose where you can hold it either by hand or vice grips/pliers on the hot post of the battery and you can kill the engine quick if need be.  The oiler on the distributor just keeps the lobes lubricated.  -Wes
| feltennova   Bronze Level   Joined: 20 Sep 2009 Location: 47161 Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 6:34am |
   Is the oiler suppose to turn with the distributor?  I ask, because mine does not.  I need to pull the distributor and see what's going on with it as I think it is the problem.
 If it does not turn so as to wipe oil across the cam, does it work off of a capillarity principle? An oiler in a distributor.  Sounds like it would make an awful mess. On advice, I'll try running a ground to the distributor, and a hot wire to the coil.  Might not get to it until Saturday as the days are getting short and there is a chance of rain in the forecast.  I need to build that other building. | |
     Bill Felten
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 6:48am |
   I would forget about the "oiler" for now, it will have no effect on your spark. You don't mention plug wires. After hot wiring the coil, if you still have a problem, remove the coil wire, the one that carries the high voltage spark from the coil to the distributor, and replace it with a new one. Making sure it doesn't rub or contact any grounded surface. | |
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 6:52am |
   Also make sure your wires are seated in the distributor cap and coil.
| BobHnwO   Orange Level     Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 7:18am |
   If there is corrosion build up between the point-condenser plate and the distributor housing there will be no spark at the points.
| Stan IL&TN   Orange Level   Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 7:26am |
   The felt is stationary.  It has only 3-4 drops of oil on it.  It is there to lube the shaft so that the rub post on the points won't wear down.  It will wear with time anyway and the point gap will increase but with some oil on the shaft it will take a long time to do it.  But as Charlie said don't worry about that now.  Fix that later.
     1957 WD45 dad's first AC 1968 one-seventy 1956 F40 Ferguson | |
| Dean(IA)   Silver Level   Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 7:37am |
   Another thought, I have heard of a C tractor which also has the ground cable  fastened to the pipe that holds up the steering shaft which lost its ground through that pipe. Try hooking a jumper cable for ground from the battery to a good ground somewhere on the tractor chassis. HTH | |
| SteveC(NS)   Orange Level   Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 10:08am |
As mentionned, don't worry about the oiler. Do, however, pay attention to the corrosion in and around the distributor. the moving point (moved by the lobes on the shaft) carries the elecrical current to ground when it closes against the fixed (stationary) point. If the metal body of the point set does not make good contact due to rust/corrosion they will not work.When the moving point moves out of contact with the grounded point, a pulse of electricity goes through the primary windings of the coil. The secondary windings, excited by the primary pulse, send a high voltage pulse to the distributor, to then be directed to the spark plug that the rotor is pointing at, thus causing a spark accross the gap of the plug (or in your case not). All this to say there must be a good contact to ground by the fixed (not moving) point. Edited by SteveC(NS) - 28 Sep 2011 at 10:12am | |
| CTuckerNWIL   Orange Level     Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Sep 2011 at 10:50am |
You might also check the insulator block that your points are connected to. The one that passes through the side of the distributor and has the red wire from the coil connected to it. If any part of that connection has the slightest possibility of grounding out, you will have no spark. Since it is intermittent, it can be harder to find, but if you check the insulator block and clean up the rust on the mounting plate, and connect the coil directly to the battery without going thru the switch or old wires,you will get rid of 3 or 4 variables and narrow the search.
 Edited by CTuckerNWIL - 28 Sep 2011 at 10:53am | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
