Big tillage question
Mark(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Big tillage question
    Posted: 05 Feb 2010 at 1:08pm
It's snowing here in Missouri so I start to think of warmer times and horsepower. Just for fun, I was wondering what is the biggest tillage equipment you all pull with your Allis? Anyone using a 30ft Field cultivator behind a 7080 or 8070? I have a 5 shank Blue Jet subsoiler that I use. Could a 7045 pull it? I'll admit to running some green paint, but I always like to wonder "what if" I had just bought all used Allis. (still use my 7010 and C).
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 1:33pm
I pull a 25' cultivator with my D-21. I have a BlueJet Tillage Pro with 7 shanks @ 20" and narrow points. At 10" deep, front discs down and the rear discs just knocking off the tops, I need every bit of 200hp. Since the BlueJet is a left over from my bigger farming days, I don't have anything of my own to pull it so swap my grain truck use with a neighbour for either a 8400 or MX 200.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 2:51pm
We pull a 24 ft. Wil-rich field cultivator with a 7045 (160hp) and a 23ft MF. disc.(I know, but it was cheap.) We 've also used  our 7020 (135hp) on the disc in the fall. Neighbor has a JD 5 shank ripper (3pt) that I'm going to try next fall with our 7045. Depends on how deep you go but I think it should work..
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:12pm
My 7060PS pulls a 24' field cult.with 3 bar harrow, also pull 7 shank chisel at 14" deep,it has dual Firestone Radials,don't pull both at the same time,lol,power is not a problem but traction is sometimes borderline.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:25pm
I pull this 5 shank Unverferth 110 inline zone builder 14-16" deep with my 79 7060 - 2nd gear low range PD tranny.  It is a load for it.  My kids love driving it.  So do I.   Also have a 24.5' AC 1300 with 3 bar harrow that it pulls.  You can see the K2 peeking out behind the tractor in the background of the photo.
DSC01096.jpg 1979 Allis Chalmers 7060 tractor picture by gleanerman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:31pm
Eric - this the one?  Mike
Edited by Skyhighballoon(MO) - 05 Feb 2010 at 3:32pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:35pm
Mike, Yes- Thank you.  It copied into my reply post just fine, but couldn't get it to convert to the message board.  What did I miss?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:51pm
Eric - when you reply to a post and want to add a pic, hit the button that looks like an arrow inside 2 step stair case that opens up the full "Post reply" window.   There hit the button that has the green tree in it to add a picture.  It opens a window with several fields on the right hand side.  First thing, delete the "http://" in that "image URL" field.
Next jump over to another window that has your Photobucket album open in it.  For the picture you want to post, copy the line in Photobucket that says "direct link" and paste it in the "image URL"  field back on the add picture window in the Allis Forum.  Then click OK at the bottom of that window.  Your pic will appear in your draft post and you can finish posting it.  Try that with your other 7060 pic and see if works for you.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 4:04pm
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 6:11pm
I have a 7060 and 7080 both running 210hp. I pull an 11 shank chisel plow with 3.5in twisted shovels, a 4 shank tye paratill, a 24ft DA1300 field cultivator, and a 26ft DA2500 disk. I have had the chisel plow and field cultivator behind my 7040 (136hp) it handles them just a gear slower.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 8:06pm
I pull a 42' pheonix harrow with my 7060 (190 hp) at 9 mph or so in 2nd fast. Weve used it with a 13 shank chisel plow 18" deep in 2nd slow, sometimes we had to flip the wings up in hard ground. We pull a 5 shank inline unverferth ripper with a NH TG285 (240 hp) with front duals and it is all it wants 20" deep.
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 9:27pm
40' JD springtooth with 7.5in sweeps with 8070 FWA in 6th low to cover the most ground.  Hardest pulling would be either a 25' Wilbeck disc in to the spools with the 8070 in 2nd low, or a 21' chisel behind a 7040 in 1st low range high.  My dad used to talk about pulling center-pivots out of wet fields with the 7040 hooked to the front of my uncle's 7050 and the front end of the 7050 never touching the ground for the full half-mile pull.
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 1:29pm
where did those front tires come from? what size are they, I noticed the tread is backwards.
A-C 608 ltd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C 608 ltd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 12:30pm
The tread is backwards to reduce roughness. We did that on our old hardi sprayer. At least that was what I've always been told.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 5:44pm
6 shank unverferth ripper, in some spots it will stop my 8550 dead in her tracks at just 15 inches deep, thats hard ground that needs ripped. In good ground not in desperate need of ripping I can run it 28 inches deep at 8 mph.
