belly mower pulley
cabindawg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabindawg Quote  Post ReplyReply Direct Link To This Post Topic: belly mower pulley
    Posted: 21 Aug 2010 at 8:52pm
Need some help...
With a little help from the forum,I was able to get my "B" purring like a kitten.
Unfortunately, one of the bearings in the belly mower went bad. I ruined the pulley getting it off. Anyone know where I can find a pulley to match(Eaton wb-1-40jbiei). I believe the deck is a danco 2587. Can't find anything on line. Any help would be greatly appreciated.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 9:42pm
The Danco mowers were more common on the small Farmalls I believe.  You might check with some folks on some of those forums if no one here can help.  I'll be interested though, as my new-to-me CA has a Danco deck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 5:33am
Check with your local industrial bearing supply houses. They should be able to come up with a match.
