B Wide Front End on CA |
Author | ||
BJ70 ![]() Bronze Level ![]() Joined: 30 Apr 2012 Location: Georgia Points: 28 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jun 2012 at 2:22pm |
I bought a B with an adjustable wide front-end with the intent of using it to convert my CA from tricycle to wide. However, once I got the B home I realized I jumped on buying the B before doing my home work; the forward attachment and steering are different between the CA and the B.
This leads to obvious questions: Can the forward attachment bracket and other unique parts for a CA wide-front end be found? Is the basic geometry of an adjustable B wide front-end close enough to be fitted to a CA? Thanks for any help.
Sponsored Links | ||
pumpkinman ![]() Orange Level ![]() ![]() Joined: 20 Jul 2011 Location: S.E. Michigan Points: 252 |
unbolt the front bolster from each tractor at the front of the motor. swap steering gears .and front ends. if you put the narrow front on the B you will have a narrow B
JarrodACFan ![]() Orange Level ![]() ![]() Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
Maybe I am being stupid, but I thought B's only had the wisshbone wide front, not an adj. wide front. Am I mistaken?
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
They were available with an adjustable wishbone and later and adjustable front similar to the CA's. Edited by CTuckerNWIL - 22 Jun 2012 at 3:19pm |
Ok, that makes sense, I just thought that B's with a adj. wide fronts were robbed off a CA at one point or another. |
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
I'm not sure about this. But I think the CA narrowed all the way will still be wider than the B front end. That could essentially make the CA useless.
MikeinLcoMo ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
Adjustable B WFE adjust from 40 inches to 65 inches.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Unless you change the steering box below the gas tank. it will steer backwards. the gears are cut backwards. at its widest seting it will be just wide enough for a narrow setting on the CA rear. my sugestion is don't do it. you will wind up with a cobbled tractor. either find a C OR CA wide front, or keep it as a narrow front. Buy the way I have both a WF CA and NF C. I can't think of any good reason the switch one over.
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9659 |
They don't steer backwards but you have to leave the CA steering arm pointing upwards. I have a C done this way with a B adjustable front. It steers better than any of my B's and turns sharper. It's at a tractor show right now but I'll get pics tomorrow and post tomorrow night. AC made a proto type called the b/c it's in Norms Book.
