B Tractor serial number
Mtnbuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mtnbuck Quote  Post ReplyReply Direct Link To This Post Topic: B Tractor serial number
    Posted: 26 Sep 2019 at 10:59pm
I was told my new B tractor that I bought at auction was a 1941 model. The serial number is B5583 which would fall in line with a 1938 production year tractor. Can anyone verify the true year of this tractor?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 6:53am
You would be correct.  If you can find one more number at the end, 55,000 would be a 41.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 5:45pm
Sometimes, throughout the years things that will bolt right to other things are replaced.  Serial numbers don't always tell the story.  B, C, CA motors all bolt right up, so who REALLY knows...?Wink
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 3:34pm
38 is hand crank ONLY!--No provisions for starter or generator!--I know cause I have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mtnbuck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 3:35pm
Well I certainly have a hand crank. No electrical, no hydraulics.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 3:54pm
Maybe who ever read the serial number for the auction dyslexia'd it, it's been known to happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mtnbuck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 5:43pm
hard to do that since it's only 4 digits after the B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 5:48pm
Not particularly, if the B looks like a 5...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mtnbuck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 8:52pm
Thank you for the cranking tip, and yes, I had seen that before. Next question, I ordered a replacement fuel bowl assembly from Yesterday's Tractor. It arrived today. Here is the link to what I ordered:
https://www.yesterdaystractors.com/cgi-bin/store/enlarge_pic.cgi?wml_910513.jpg:910513
When it arrived, I noticed it was different from what was on the tractor. The original is brass. The replacement I received is not brass, but aluminum. My fuel line fitting is brass. If I connect the two, I believe they will eventually fuse together due to galvanic corrosion. I am disappointed and have to return it. Can anyone recommend a good source for parts/components that are more true to nature of what I have on my B?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 9:28pm
Try an Agco dealer, near you, Their on-line catalog, or Sandy Lake Equipment, a site sponsor.  YT sells a lot of cheap chinese, or indian stuff.  You may find that that sediment bowl was made of who-knows-what pot metal...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 6:32am
Every tractor I have owned has had the pot metal sediment bowl casting. I have never had any trouble with dissimilar metals fusing to them. The biggest problem seems to be a warped surface, where the bowl and gasket seat or a leaking packing nut on the shut off.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 6:35am
I wouldn't send it back until you find a brass one. I doubt you are going to find a new sediment bowl with a brass housing. The ones like you have work okay.
I have used the (non-brass) housings and I have never seen the fuel line fuse to the sediment bowl. They only used brass on a few of the early tractors. Most never had brass sediment bowl housings.
If you are concerned, there is a fitting that threads in between the sediment bowl housing and the fuel line. You could use a brass fitting there. The worst that could happen would be you would have to buy a new fitting if you can't remove it from the housing, but, again, I have never seen a problem with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 9:43am
Put thread tape on it and never look back!--Trust me they will never fuse!--been around them for 60 years and never saw one fuse!--All you can get nowdays is the luni crap and as stated, they can warp and leak but thats the chance you have to take.
Mine is also a 4 digit serial #, --have it here somewhere but don't see it right now.
38 had no hyd., also they have mag. ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 10:00am
There's also Anti Seize which I find very handy.
Edited by chaskaduo - 29 Sep 2019 at 10:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 5:44pm
My B serial # is B4925, just looked.
