B oil leak
mweiland View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mweiland Quote  Post ReplyReply Direct Link To This Post Topic: B oil leak
    Posted: 06 Mar 2015 at 3:05pm
hello, I have a 38 allis b that has some oil coming out through the clutch inspection plate. I was speaking with my uncle about it and he seemed to think you may change that seal from on the crank side without splitting the tractor. I have never done either, and our repair manual is snowed in at the cabin. ? 1.what is the name /part number for said seal. ? 2. do you have to split the tractor to replace it. thanks for any help , Matt
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 3:46pm
You will have to split your tractor. remove clutch/ flywheel/ oil pan and seal retainer. You will need a cork rear main seal a seal retainer gasket and an oil pan gasket
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote mweiland Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 7:41pm
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 8:56pm
You might also want to change the seal on the shaft going into the torque tube while you are at it.  I've seen those leak as well.
