B engine freeze plugs
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Topic: B engine freeze plugs
    Posted: 20 Jan 2020 at 3:12pm
I popped out the freeze plugs when cleaning up the block for rebuild.  Didn't realize they weren't a standard cup shaped plug, but just a saucer shaped disc.  Will a standard plug go back in the hole?  They seem a little shallow for the cup type.
And yeah, they aren't technically "freeze" plugs since they aren't in the water jacket.  Casting plugs?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 3:19pm
Agco Part # 70910011 Welch Type 2.500 Saucer Type As Some Call Them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 3:53pm
Excellent, just what I needed!  Thank you!  Never even heard the term Welch plug before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 5:42pm
I think the term AC used in some lit., was core plug.  You should be able to take an old one into a rad shop, or auto parts house, and come out with a new one, for not much $...Wink
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2020 at 5:48pm
A common term used for plugs in the small engine carbs.
