B Crank Start Engine Pulley
GLHolmes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GLHolmes Quote  Post ReplyReply Direct Link To This Post Topic: B Crank Start Engine Pulley
    Posted: 19 May 2010 at 8:34pm
Hello everyone, my dad just bought a 1939 Allis Chalmers B crank start.  The tractor looks OK and runs great...when we can get it started.  The previous owner had rebuilt the engine and it really does run nicely, but the engine crankshaft pulley has gotten worn down; specifically, the grooves that the crank seats into have worn away and it's hard to get the crank to bite into the pulley adequately.  Called the local Agco dealer and was told that they still make this part brand new in limited quantities--for $243.  Does anyone have an idea where we might be able to find this part used (in REALLY good condition) or brand new (for a little less than $243)?  Thanks for any help.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 8:54pm
Welcome to the Forum! I'll bet that there's a good used part out there......or perhaps you could get someone to add some metal with a welder and then recut the notches with a grinder. With the radiator removed, this could be done right on the tractor. Good luck!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:04pm
I think I have a pulley that probably looks like yours. Somebody out there has a good one or you could do like Dave says. Find somebody to build yours up some.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:42pm
Thinking about it, there has to be a good supply of good used pullys that never saw a hand crank.  After all, there were lots more Bs Cs and CAs with electric start than handcrank only Bs. I may even have a few stashed away just in case I rebuild another handcrank B. They are cast iron and plenty get broken getting them off when rebuilding a engine.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 6:17am
I don't know how bad your pulley is without seeing it but I have renewed a couple of them by clamping them in a mill vice and plunging cutting a 1/2" mill cutter to reshape the catch for the crank pin. If a hunk has not broken off it should work.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 6:20am
$25.oo plus shipping.PM me if you want it.Will send pictures so you can see it is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GLHolmes Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:01pm
Thank you everyone for your help and advice! I've got a new (old) one on the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:34pm
Excellent! Let us know how you make out, please.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote GLHolmes Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 4:56pm
All right, been working on getting the old pulley off, without much success.  We've been pouring lubricant to it and heating it up with the blow torch for 5 minutes or so, and it won't budge.  Does anyone have an idea for us?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 5:07pm
Take the second set screw out. Some had a double set screw, one to jam the other.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 5:09pm
There is a set screw on there. You will have to use a gear puller. I have used 3 short nuts and bolts behind the pulley in combination with a puller.  Put pressure on it from behind by cranking out the nut. They have been on there for up to 70 years.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote GLHolmes Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:29pm
Still working on it and looking it over; we cannot see a second set screw.  We only found one set screw on the backside of the pulley on a raised portion of the collar.  Also, the pressure of the gear puller is breaking the back side of the old pulley right off.  Please help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:31pm
Where in MI are you located? I wonder if one of the guys on here could take a look....
WC, CA, D14, WD45
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:08pm
This is what I use to get those pulleys off. Some of them I had to get red hot but never broke one.  Some of them are tight.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:49pm
Ray's right.  Went thru this in March.  Thought for sure it was going to break-but it didn't.  Heat and steady pull from a good gearpuller.
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:55pm
Both set screws are in the same location - one behind the other.  I found out the hard way getting the pulley off of my D14.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 11:55pm
A bearing separator placed behind the pulley distributes pressure from the puller well...  Just a suggestion   -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 6:37am
If there is any shaft sticking out from the front of the pulley, clean it and remove any paint or burrs. Wire wheel, sandpaper, and a file. If you have pulled it out some, spay penetrating oil on it and tap it back in.
reggleston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reggleston Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 6:57pm
Hello, I just purchased a 1946 B, and am getting my nuts busted constantly... I think the starter was rebuilt backwards since the positive line damn near melted as I tried to jump start it... I was hoping to purchase the hand crank that you wrote about to try it out...
Thanks, Rob.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 10:09pm
Are you aware that the positive wire is the ground wire on a 46B.
Did you have your jumper wires reversed?
Bob
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 5:46am
My experience with these pulleys is that you need a really good puller. I have broken a few of them with pullers. I believe I have heated them a bunch to get them off.
 If the one you have on there is shot you may even consider cutting it off with an angle grinder. Maybe cut a groove on opposite sides enough so that you can crack the casting with a chisel?
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 8:03am
Saw a used one on e-Bay last night. Price was starting at 9.99  It was listed as crankshaft pulley
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 11:00am
Fred's price is good.  I usually get $45 four ours.  I have about  a 50% ratio of getting them off without breaking.  But then most of what I'm working on has set dead for a long time.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 1:05pm
I had this happen a while ago, on a D-12.  Book said you needed a very big puller.  Rented one and broke the pulley.  That pulley i think has a woodruff key (D shaped) in it.  With the engine turning in one direction for over 70 years, the key bites into the side of the keyway on the crank shaft.  With everything cleaned up, you should be able to see the keyway in the pulley and in the crank shaft.  put a bolt in one of the side holes in the pulley and with a punch and hammer tap (rotate) the pulley till both keyways are aligned.  Should come off easy then.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 4:47pm
I'll have a look tomorrow but my neighbor is a machinist and he makes and sells a special crank pulley remover for the Farmall Cub. That pulley a press fit over 2" on the crank. This remover uses a bottle jack like a portapower and there is a plate designed to pull from the hub and not out on the edges like 3 jaw pullers. This just might work well on these pulleys as well. This puller probably has pulled hundreds of pulleys without breaking a single one and these have to be tighter than the Allis setup since they are a slip fit to begin with.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 10:32pm
 Look at the picture that Rich Akin posted thats all the tools you need . put the heat too  it get it red hot it will come off and if it breaks so what it was worn out thats why  you want one thats not   right. ore grind, drill, weld ore whtever  wen the engine  backs while your cranking and the crank dozent come out you can call me and  I give the name of the DR. who put my wrist back together.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 6:51am
Took one off yesterday.  Like everyone says remove the locking screw.  Put your puller on and heat the pulley with a propane torch.  It will bust loose.  Also you may want to heat the pulley then spray with rust buster.  As the pulley cools it will wick some of the rust buster into the seams.  Turn the crank so the lock screw hole is facing up and spray some rust buster into the hole.
Do the next guy a favor when they are rebuilding it again in 70 years---Anti Seize !!!
Bob, North Carolina
1949 B
jayjay145 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jayjay145 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 7:22am
I'm in need on a good used hand start crank pulley for my 1938 B as well. Anyone have one they could part with? Thanks!
