B/C engine oil lines to head and governor. |
| Author | ||
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: B/C engine oil lines to head and governor.Posted: 10 Jul 2012 at 10:18pm |
I need new oil lines. The short one from the oil filter area to the T fitting on head has sprung a leak. Rust got to it. I would like to replace the one going to the governor also.
It looks like a conical compression fitting. All I see in the stores are the double bevel "bead" compression fittings, and too large in diameter. What is it called, what size, where to purchase? |
| Sponsored Links | ||
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3810 |
Posted: 10 Jul 2012 at 10:57pm |
I have some good used ones that i will sell. send me a PM or email me at mbsctt881@hotmail.com if intertested. Thanks Matt |
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 11 Jul 2012 at 8:02am |
You could also re-plumb using plastic oil pressure gage tube and fitttings.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
wkpoor
Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
Posted: 11 Jul 2012 at 8:16am |
McMaster carr has the lines and fittings. The Tee fitting will look a little different though.
My guess is most tractors have the lines plugged up and should be cleaned or replaced. Edited by wkpoor - 11 Jul 2012 at 8:17am |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 11 Jul 2012 at 3:53pm |
You really don't want to change the tee in the head. It has the orifice to meter/slow the flow and could drop the oil pressure.
wkpoor
Posted: 11 Jul 2012 at 4:07pm |
Thanks Dick, I didn't know that. If a guy couldn't find an original I'll bet it wouldn't be hard to install one. Find an allen set screw that just wants to screw in and drill the center. I just sold one of those tees a few weeks ago. I'm going to look at another to see. |
wkpoor
Posted: 11 Jul 2012 at 5:03pm |
I went out to look and that hole in the tee looks to me to be the same or larger than the tube. Maybe that hole didn't need to be any bigger because of the tube size. Either way I expected to see and real small hole if it was to control oil pressure.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 11 Jul 2012 at 10:25pm |
you can buy copper oil line and fittings in a kit at Advance Auto or Auto Zone, about $12.00. It has the correct ferules with it. I have used standard plumbing type 1/8" ferules and they worked OK. All you want to do is squeeze the ferule around the tube and against the fitting. The area at the nut end doesn't seal anything, it just presses. Bob
BrianC
Posted: 11 Jul 2012 at 10:53pm |
Is the Sunpro CP7584 the right kit?
The conical ferrules look about right. That is a copper line kit, they also have nylon. Is the ferrule at the governor a standard "double bevel bead" type ferrule? Thanks. |
wkpoor
Posted: 12 Jul 2012 at 5:17am |
McMaster has the lines in stainless only I believe.
The governor has the same ferrules yes. |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2724 |
Posted: 12 Jul 2012 at 8:06am |
At one time, Steve in NJ had made some of these up. Don't know if he has any left or not or if he still makes them. FWIW.
