Auto Steer On 100/200 Series ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Auto Steer On 100/200 Series ?
    Posted: 12 Jun 2020 at 8:22pm
Is it "possible" to install the "latest/greatest" auto-steer technology on the old horses ? I really have no idea how the new stuff works, but I seem to recall pictures of o "gizmo" mounted to a steering column with a wheel that turned the actual steering wheel but that was a LONG time ago in a S/F or P/F magazine in the early '80's LOL !!
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 8:37pm
Don't know about applications but the first one I drove had the little wheel against the steering wheel. I think the accuracy was a foot or so, newer ones are down to an inch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 8:45pm
IIRR, there is a write up on an affordable auto-steer system, in either the last issue, or the one before, of farm show magazine.  Question is is it cost effective, to put a system costing about the same price, as the value, of the old AC tractor?Wink
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:57pm
I have an ontrac 3 agleader with a compass display in my 7060. A gear ring clamps to the steering wheel and a motor goes around it and snaps on. It’s really accurate compared to the ontrac2 or 2+. It will stay less than 4” at 7mph and closer yet at slower speeds. It was around $5000 for everything though. It will literally go on about anything with a steering wheel though.
Edited by 7060 - 12 Jun 2020 at 9:57pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:58pm
Not sure if mounting brackets are available for 100/200 series if not I’m sure one could be made.  This week been pricing a kit from Trimble to go on my 8030.  To get accuracy good enough for tillage or fertilizer spreading sounds like $3500 ish to get planting accuracy sounds like $4500 ish.  Wheelman Pro are sub $4000.
Could it be potentially financially feasible on older tractors?  My answer yes.  I wouldn’t spread fertilizer or spray without atleast a light bar.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 10:02pm
I use a 1500. dollar Trimble 500 EZ steer unit on my Agco planting tractor. Is it perfect, no . Is it better than I can do, maybe. But it’s pretty darn close. I can put it on my New Holland 4 WD. Or my Gleaner R66 combine, or a 190, or a D17. The fact is ,the more you spend the better the results. But yes, you can make auto steer systems work with old iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 12:07am
I inquired about the Wheelman system. They told me that if the splines matched up, it could be installed on a D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 5:32pm
Funny you should mention the D series Smile, I was curious about them also LOL!!
Just "what" is involved "tractor-wise" as far as adding the auto-steer BELOW the "globe"; plumbing/electrical etc. ?? How does it physically steer a tractor ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 9:40pm
EzSteer has a small wheel that turns the steering wheel
This page was generated in 0.219 seconds.
