Are my eyes lying to me?? 190 Rearend?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: Are my eyes lying to me?? 190 Rearend?
    Posted: 18 May 2012 at 7:34pm
Still in use:
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 7:58pm
  no not lying --we have 190 rebuilt with new seals etc.ready to install   pick up here
   us30 northern ind call 1-574-342-4545  3 1/4" axles
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:38pm
That's a 180,185 looks like to me
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:42pm
Well the actual rear looks 190ish, but the shift tower, is not.
Still in use:
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:46pm
it is a late 190 or 200 rear end but has the 185 shift cover.
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 9:59pm
So, by the looks of this, you can put the 190-200 rearend on a smaller 100 series tractor? I am having a hard time seeing that it either does or doesnt have straight axels. Looks like it....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 11:00pm
Brakes are exposed, so it is a straight axle.....the gear shift threw me off too, but i have seen another pic of a 190 with a gear shift like that.....
ALLIS EXPRESS!
This year:
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 11:30pm
Nothing like my 190XT rear end and trans.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 11:44pm
Looks to me like someone put a late 190 or 200 rearend in their 180 or 185 tractor. Would be interesting to see more pictures of Johnny Cash's cadillac tractor.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 6:38am
The tractor must be a 180 or 185.The foot rests,seat,brakes,brake lock and gear shift are all 180 or 185.The rear end is either 190 or 200.It would be a bit of a nightmare to get the hydraulics and lever linkage rigged up.You can see the hydraulic hoses strung along to the rear of the tractor.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 6:48am
Could be D19 with 180 gear shift.  MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:55pm
That is not a 190 or 200. They had platforms and drop boxes. The seat mounted on the fuel tank and the platform. The brakes are wrong as well as the shift cover. I guess It should say everything is wrong. It looks nothing like a 190 or 200,
It look like a a 180 or 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:00pm
I think Mack nailed it....can't be a 180/185 rear end because of the brakes, D19 used a top plate like that.....it is a D182 1/2!
ALLIS EXPRESS!
This year:
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:22pm
Can't be a D-19 rear with the 3 1/4" axles. It is a one ninety rear but bolted to a 0ne- eighty or 185 transmission and I assume one eighty or 185 tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:31pm
I'm not familiar with the top of the 190 since mine has a cab covering up things...so I will bow to your wisdom Cal! All I know is that it is not a 180/185 rearend...
ALLIS EXPRESS!
This year:
This page was generated in 0.095 seconds.
