Another sickle mower question
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: Another sickle mower question
    Posted: 25 Sep 2016 at 9:35am
I have an 82t mower. It has a double acting Prince cylinder with a vent in the bottom port. What was the correct Allis Chalmers cylinder used with this mower?
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 10:04am
I forgot to ask what was the belt size used on this mower.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 1:05pm
*********C104  (70804122) ...Dale
Orangereborn
Dale Schafer
964  192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 6:42pm
The correct cylinder will be determined by the tractor pulling it.  Older systems, use 3500 psi one way cyl, newer systems can use a lower pressure 1500 psi cylinder...  State the tractor you plan to use, and we can tell you the correct one to use...
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 3:06pm
The tractor I am using it with is a WD45. The owners manual for the mower shows a cylinder with the hose fitting on the ram end of the cylinder, not the bottom like an Allis single acting cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 5:49pm
 This is the cylinder used on the mower.  I think it is higher pressure rated than the standard 2 way but it functions as a 2 way. Probably similar to the 3000 PSI of the welded construction version.   It is not at all like the original AC high pressure design. Many regular 2 ways were used on AC High pressure systems but you could blow them out if the tractor pump was up to full pressure capability. AC also used this 2 way before they went to low PSI systems.  You should be able to use this cylinder on most any tractor......Dale
Orangereborn
Dale Schafer
964 192nd Ave
715-247-3079
715-781-2055
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 6:29pm
if your using it on a WD45 the correct cylinder would be another WD45 cylinder. the implements usually had a cylinder matching the tractor cylinder. We traded a # 3 three mower the dealer took off the WD cylinder and put a C cylinder on in its place. since we put the mower on a C the larger WD cylinder took to much oil.
