Allis-Chalmers Survey
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers Survey
    Posted: 17 May 2012 at 1:02pm
Hey Forum Members,
I made a small 10 question survey, just for fun, to gauge what is some of the main interests in the AC tractor line. I would appreciate it if you would take a min out to take the survey. I will post the results later! :)
Thanks,
AF
"Better By Design"
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:23pm
Done. There were a couple I would have liked to choose multiple answers.
David Gibson
http://www.darkecountysteam.com
1956 WD45
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:37pm
Likewise done...been too long since I have been on the farm so did not answer tha last one
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:41pm
Done -- also did not answer last one - would have just been a guess, not data based.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:41pm
Done
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:45pm
DoneSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:46pm
The last two were just curiosity ones. I am interested to see which one people think are good/bad. I think I will make a follow up survey after this one to see why people think a particular model is good/bad.
"Better By Design"
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:20pm
I agree, the last two to give an informed opinion, one would need a lot of experience.  Some of the contributors could give valuable insight.  My experience is too limited.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:23pm
Done
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:28pm
1. learned to drive on a WD at age 6, orange had a sappy governor, and with the snap coupler and mounted equipment, it could go thru lots of places the drawbar equipment could not. hand clutch was the best thing too. Green was ok, but still liked the quick responses on gov of orange no matter if it was the fifty's models or into the seventies...190XT sat better, hydraulics better, power steering quick, rear ends and trannys did not hold up as well in early ones.
2. Love the steel, don't need to pump them up, hate the ride, jar your guts out on hard ground... Love rubber for smoother ride and actual more traction.
3. Love the styled and unstyled... the past and the present... which style are you talking about? the WD or the XT or the 1000 series?
4. Gas in the winter, easier to start, diesel in the summer, more fuel efficient, LP gas for cleaner oil and cleaner combustian and lesser headaches from exhaust... and a greater deterrent for theft of fuel...
5. Singles hop to much, would love to have my XT sittng on a narrow front. easier to get into tighter places, nicer for corn cultivation... wide front better for ride and safer...
6.Snap coupler had its unique advantages but harder tp hook up sometimes... 3pt is everywhere so more tools can be hooked up and go.
7. What era were AC's built the best?  Depends on some factors... who likes what... I hate electronic gizmoes on tractor, simple mechanical controls and instumentation instead of sensores and computer controlled.. So hence the early part of 70's  But the 1914-1940 were rugged old beasts that were just that rugged, 40's & fiftieswere little bit more refined and 60's &70's more refined and then the 80's... never got to own one of them...
8.What do you call small medium and large HP? Little B allis, had no time for them other than to cut yard grass and pull the hayrope or run a rake... Most of the work was done with WD-45, D17 then heavy work was 190XT , 1855 and 4520
9. 190XT III, 210/220.
10. worst ones? the ones gone to the scrap yards...
 Well the survey was not conclusive enough for my thoughts... Like is fire good? It isn't when your house is burning down... but it is for cooking and keeping you warm...LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:33pm
It's an opinion based survey. No right or wrong answers.
"Better By Design"
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:37pm
Done,  I like steel wheels with rubber tires. Those rubber wheels are a little wolebly.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:37pm
You should have given us a choice of :" pin hitch"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:50pm
Done
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 2:58pm
Done.Thumbs Up
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 3:17pm
Done
"Burgie"
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 3:33pm
Done
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:11pm
   Since the parameters of the survey will not let me answer honestly, I will do it here.
 1. Both Allis Chalmers Green and Orange
 2. Both
 3. Both
 4. all
 5. all
 6. Snap Coupler ! Far superior !
 7. all
 8. all
 9 and 10. There are a lot of variables to these two ? Different operators, environment, care, etc.
http://www.rumelyallis.com
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:21pm
Done
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:39pm
My #10 answer was 'none' lol
Chris N Ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris N Ky Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:12pm
done- Fun survey
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:16pm
Yes to all but the last one.
The universal answer to all questions is yes, how much do you want to spend?
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:25pm
All done
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:30pm
Done !!
Allis5020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis5020 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:40pm
Done.  WD-45 all the way!  ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:45pm
Survey is closed! Got 100 responses exact! Just what I wanted! Thanks to everyone who participated. :)
"Better By Design"
This page was generated in 0.277 seconds.
