Allis Model G
fireman1694 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fireman1694 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Model G
    Posted: 09 Sep 2012 at 7:22pm
Restoring a 48 G back together almost ready for paint, can't get any fire to the plugs. New coil in,  new condenser. Coil states no resistor needed. (it's internal) Does the positive side of the coil go to the condenser???
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 8:55pm
If the battery is installed positive ground then dist side of coil has to be positive also.
I had a similar problem after I rebuilt my G. Got rid of the new AC plugs and installed used Champions and it started right up. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:02pm
I believe the coils that have a coil that has a resistor in it is met to be used with a 12 volt system.
The G came with a 6 volt system.
Where in MIchigan are you ?
 I have a coil I bought, I asked for a 12 volt one and was told that it was for 12 volts. When I opened the box there was a note with it stating it needed a ballast resistor with it. So it is a 6 volt coil.
It's not practical to take it back, and I don't need it.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote fireman1694 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:56am
I'm located between Vicksburg and Scotts, south and a little east of Kalamazoo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:47am
I was hoping you were closer to me. I'm between Charlotte and Grand Ledge.
The G came with a 6 volt electrical system. I'm going assume that it still is 6 volt.
Check to see if you have 6 volt going to the coil.
Also it sounds like your coil is made for a 12 volt system, 6 volt systems do NOT have or use a resistor.
Dusty
Edited by Dusty MI - 11 Sep 2012 at 6:48am
This page was generated in 0.111 seconds.
