allis chalmers WC tractor rebuild problems
mikefoxFARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikefoxFARMER Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers WC tractor rebuild problems
    Posted: 07 Dec 2011 at 10:14am
hi guys, new to the forum. anyways, i got a 1939 allis chalmers WC gas tractor or rubber that im rebuilding, my problem is i dont know how to get the starter motor off. ive taken the collet bolt out of the L/H side of the machine, and it just wont budge. soaked it with WD40 and tried prying it out, but we couldnt make it move, any suggestions? or am i going about it wrong?. this was my great grandfathers tractor, so we have no manuals or parts diagrams for it at all. grandpa barely remembers how to work on it. any help would be appreciated
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 10:28am
Two things hold them, the bolt you removed and rust. I have had luck with bumping the starter with the bolt loose or out, 12V helps here. Hardwood 2x4 and 4lb hammer needed sometimes but dont beat on it like it's unbreakable  as the nose is a casting.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 10:36am
I've had good luck with getting stuck ones out by soaking with penetrating oil around where it goes into the bell housing and then using a thin chisel as a wedge and carefully drive it into the joint from one side and then the other until it comes loose.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 2:11pm
I have also had some luck bumping them with a rubber mallet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikefoxFARMER Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 4:53pm
thanks alot guys, going out to the barn to try it tonight! wish me luck.
