Allis Chalmers Model 500 Loader Help |
gordonh ![]() Bronze Level ![]() ![]() Joined: 04 Oct 2013 Location: West TN Points: 144 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Oct 2020 at 7:06pm |
I have a AC loader model 500 taht I need some hlep on. I have a peice that is on the hydulic pump drive that I need to know about, It connect the pump to the crank shaft. I have uploaded pictures of the peice I was wandering about. Does anyone know if the shaft rod that goes against this pecie is suppose to be welded or if it was threaded in it. Any help is apprecited. uploads/10326/IMG_1058_2.JPGuploads/10326/IMG_1059_2.JPG
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21995 |
What model tractor ????????? looks homemade to me.
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Been my experience that there is usually a keyed or splined hub welded to that piece and the corresponding shaft slips into that hub. Supposed to make it easier to change the belt and such.
D 17 gas
That ain't factory. Factory had a splined cast iron hub and a splined shaft with a chain coupler on the pump end.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
I believe you have a Model 400 Loader if you have a front pump, Model 417 on an earlier D-17. |
DaveWisc. ![]() Orange Level ![]() ![]() Joined: 11 Oct 2009 Location: Wisc. Points: 1012 |
A and W in Wisc makes new reproduction of the assembly they have the hub and shaft along with the shaft. I have there number if interested .
Thanks can you send me the number? Do you know how to tell what model the loader is? I cannot find a serial number on it? Here is some pictures of it.uploads/10326/IMG_1063.JPGuploads/10326/IMG_1064.JPG
How will I know if it is a model 400 loader?
D17
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10816 |
There are several differences over the span of the manufacturing. What tractor is it on? The cross bar that ties the uprights will be close to fuel tank if a 400 series. The 500 series upright is taller and bar will be several inches off of tank. Both models had a reservoir in one of the uprights on some models. Later ones did not. HTH Tracy
