Allis Chalmers G dually?
Nitro1207 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitro1207 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers G dually?
    Posted: 04 Jul 2019 at 4:05pm
Did Allis Chalmers make a G with factory dual rear tires? Or are these just add on’s people do?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 9:02pm
Add on.  The axles really are not strong enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitro1207 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 9:30pm
I wondered. I see one every once in a while and didn’t know if it was a factory option or not.
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 10:38pm
I have a friend who tested the G's at the plant.
He told me about reported issues with the brake drums. They tried different things to help with the problem such as different metal in the drums and welding the hubs with different type of rods. He said the problem came from turning hard at the end of a row. AC wanted to simulate what was happening and also add more stress to the drums for testing. They decided to put duals on a tractor that was being built. He got on the tractor and let off of the clutch fast which ended up breaking both axles right there at the end of the assembly line.
He has a a lot more tales about the lengths AC went to build a better product and make customers happy.
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 10:43pm
Cool story. Would love to listen to hear more.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 8:46am
I have a set of rims for a G that are very narrow 5 inch wide? I also have the tires that fit them. They are rough but could be used. 5 x 30 is the tire size. I am looking for a home for them if interested.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 9:25am
I had a Chevy Corvair. Clear in the back was the engine, then clutch, then, rear axle, and then the transmission. The drive line went through the rear end to the trans and back to the rear end. Is that how it is done on the mighty "G"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 9:29am
And I remember some one posting a photo of their "G" with a caption that every tractor had to have a purpose. They built a smoker under the frame so they could drive the parade rout and smoke meat at the same time.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 12:37pm
The G uses the same transmission that the B & C uses. When used on the B & C there is a shaft that runs around the gears, that runs the PTO and hydraulic. On the G that same shaft runs from the engine to the front of the transmission and runs/feeds the transmission.
Clear as mud?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitro1207 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:55am
So it sounds like the G’s did not come with dual rear wheels as a factory option and are an “add on” that are probably not really safe or practical if your going to do anything with the tractor besides putt around in a parade or two a few times a year. That sound right?
