Allis chalmers B pto hydraulic swap |
jimbob0406 ![]() Bronze Level ![]() ![]() Joined: 21 Jan 2015 Location: MN Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2015 at 6:36am |
I have a 1950 allis chalmers B. When i bought it it did not have a pto or hydraulics. It had the differential cover with the pointy cone. So i went on ebay and bought a pto hydraulic assembly. but now it looks like i need a gear that goes on the end of existing shaft and retainer clip. Is this so? anyone do a swap maybe a couple of pictures anything be highly appreciated.
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
Yes you need the drive gear. They are on ebay frequently,
http://www.ebay.com/itm/VINTAGE-ALLIS-CHALMERS-C-TRACTOR-PTO-DRIVE-GEAR-SNAP-RING-1948-/300927289498?pt=BI_Heavy_Equipment_Parts&hash=item4610aa089a Or put a WTB in the classified section of this site. |
Thank you i appreciate that. Since i have a later year B would that be the same as the C drive gear you posted by chance or should i look for one from that year?
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
The gear was all the same. We mounted them all the time and there was not a problem putting a newer 1 3/8" PTO on an older unit 1 1/8" PTO without changing out the gear that was on the unit. Take good care of my favorite. Good Luck! Bill Long |
So the C had a touch bigger shaft than the B is what your saying?
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
no yrs. was the difference-1 1/8 early later an 1 3/8
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
1 3/8 spline is standard size, early tractors had 1 1/8 and you would have to add an adapter to fit a regular PTO shaft.
Well if I have any questions i know where to ask. Also do people RTV the housing or is it recommended to get a gasket? If so does anyone have a part number or one on Ebay? 1 more thing What year color was on the 1950 B. thanks
You need the gasket. The AGCO number is 70225385 current price is $7.45
(original Allis # was 225385, Agco numbers start with 70) |
