Allis Chalmers 230 gas combine engine in WD45
Preston230 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 230 gas combine engine in WD45
    Posted: 08 May 2018 at 9:24pm
Ok so i wanna put a 230 gas combine engine in my wd45 gas frame. Will i have to do anything other than a starter, flywheel, and adaptor plate. Will i need to have my crank ground or anything?
       Thanks
              Preston
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 9:31pm
Gas radiator won't work. What are you using for a governor and throttle linkage??
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 1:16am
I have put a couple in diesel frames that gives you the adapter plate,starter,radiator,hood and flywheel,as far as the governor and making a front mount the front plates and governor off a Cockshutt
30,40 or 50 makes for the easiest conversion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 5:16am
Ok Thanks for the information. I will probably have to find a governor for it and use linkage off some thing else or make it.
