Allis Chalmer b 116 HELP!
rbthefirst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbthefirst Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmer b 116 HELP!
    Posted: 10 May 2017 at 3:31pm
I just bought an Allis Chalmers B 1940. I don't know very much about tractors. It has a 116 cubic inch BE engine. I need to find a place to buy an engine rebuild kit. Does anyone know where I can get them? I have looked everywhere online and I keep finding 125 C.I. engine parts. Do some of the 125 engine parts fit the 116 C.I. engine?
Edited by rbthefirst - 10 May 2017 at 3:41pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 5:20pm
The 125 is a newer version of the 116. All the parts will fit, just make sure you change the sleeves.   I think they got the cubes out of bore.
AaronSEIA
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:10pm
All the B125 kits will work. 116 and 125 are the same except piston diameter.
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:25pm
Congratulations on obtaining my favorite Allis Chalmers Tractor.  You will find it to be very basic, dependable, and durable.
As stated above all the 125 engine kits which include sleeves, pistons, rings, wrist pins, and sleeve seals, will fit the 116 engine block.  We installed many of these kits and they worked well.
Take good care of my favorite.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbthefirst Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 10:51am
I just want to say thank you to everyone for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbthefirst Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 11:01am
Does anyone know where I can buy crankshaft main cap bolts? The tractor was partially tore down when I got it and 2 seem to be missing.
Edited by rbthefirst - 12 May 2017 at 9:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbthefirst Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 2:59pm
Do you know where I can buy crankshaft main cap bolts?
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:04pm
Any of the vendors listed on the site are great to work with.  I have used many and had good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 4:56pm
IF you don't find original, I would think McMaster Carr or Fastenal would sell grade 5 bolts with drilled heads for the lock wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 4:57pm
Steel Wire-Lockable Hex Head Screws - McMaster
Fully Threaded
Partially Threaded
Wire these screws together through the hole in the head to get more vibration resistance than any other screw (wire sold separately). They are made from zinc-plated Grade 5 steel that’s stronger than stainless steel and provides corrosion resistance in wet environments. Length is measured from under the head.
For technical drawings and 3-D models, click on a part number.For technical drawings and 3-D models, click on a part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbthefirst Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:51am
This is my Allis Chalmers. I only paid $300 for it.
