Allis Chalmer b 116 HELP! |
rbthefirst
Joined: 10 May 2017 Location: philipsburg Points: 15 |
Topic: Allis Chalmer b 116 HELP!Posted: 10 May 2017 at 3:31pm |
I just bought an Allis Chalmers B 1940. I don't know very much about tractors. It has a 116 cubic inch BE engine. I need to find a place to buy an engine rebuild kit. Does anyone know where I can get them? I have looked everywhere online and I keep finding 125 C.I. engine parts. Do some of the 125 engine parts fit the 116 C.I. engine?
Edited by rbthefirst - 10 May 2017 at 3:41pm |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Thanks(1)
Posted: 10 May 2017 at 5:20pm |
The 125 is a newer version of the 116. All the parts will fit, just make sure you change the sleeves. I think they got the cubes out of bore.
AaronSEIA |
CTuckerNWIL
Thanks(1)
Posted: 10 May 2017 at 9:10pm |
All the B125 kits will work. 116 and 125 are the same except piston diameter.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Thanks(1)
Posted: 10 May 2017 at 9:25pm |
Congratulations on obtaining my favorite Allis Chalmers Tractor. You will find it to be very basic, dependable, and durable.
As stated above all the 125 engine kits which include sleeves, pistons, rings, wrist pins, and sleeve seals, will fit the 116 engine block. We installed many of these kits and they worked well. Take good care of my favorite. Good Luck! Bill Long
rbthefirst
Posted: 11 May 2017 at 10:51am |
I just want to say thank you to everyone for your help.
rbthefirst
Posted: 11 May 2017 at 11:01am |
Does anyone know where I can buy crankshaft main cap bolts? The tractor was partially tore down when I got it and 2 seem to be missing.
Edited by rbthefirst - 12 May 2017 at 9:45am |
rbthefirst
Posted: 11 May 2017 at 2:59pm |
Do you know where I can buy crankshaft main cap bolts?
DanC911
Posted: 11 May 2017 at 3:04pm |
Any of the vendors listed on the site are great to work with. I have used many and had good results. |
Joined: 11 Sep 2009 Location: illinois Points: 89178 |
Posted: 11 May 2017 at 4:56pm |
IF you don't find original, I would think McMaster Carr or Fastenal would sell grade 5 bolts with drilled heads for the lock wires.
Posted: 11 May 2017 at 4:57pm |
Steel Wire-Lockable Hex Head Screws - McMasterFully Threaded Partially Threaded Wire these screws together through the hole in the head to get more vibration resistance than any other screw (wire sold separately). They are made from zinc-plated Grade 5 steel that’s stronger than stainless steel and provides corrosion resistance in wet environments. Length is measured from under the head.
rbthefirst
Posted: 12 May 2017 at 9:51am |
This is my Allis Chalmers. I only paid $300 for it.
