Allis CA |
Page <1 17181920> |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8647 |
Posted: 02 Sep 2025 at 3:10pm |
Paul,
Could you post a picture of the B/C side weights used with a longer bolt? Might help someone working on this old iron too. Folks, I just cleaned up the longer, lower steering arm, the side weights, and the knobs they set on. Shot some high build primer on them maybe I can put some of that shiny PO#1 on them soon. The crude paint booth has helped reduce the over spray in the shop a lot! This old CA was a misfit when I bought it and hasn't gotten much better in my possession either. I did talk with Brenda at Sandy Lake Impl. and ordered a seal for the PTO shaft. That may reduce the oil dripping from that area? Still have a pesky leak from one of the rad hose connections. Like most of the other Allis tractors we have, they all mark their territory! Also dropped off the IH rear wheel weights to get them cut in half. They have several saws that should make short work of those. I am going to make some brackets and sq tubing to allow our 15 lb weights to be added if needed. Here is the short arm, key, gear and bolt. It almost fell out of there!:) The old sandblaster helps clean these items back near original condition. Regards, Chris and Cheryl
Edited by Sugarmaker - 02 Sep 2025 at 3:15pm |
Sugarmaker
Posted: 02 Sep 2025 at 9:21pm |
Guys,
I did get the parts painted to put the steering back together. Just like you guys said it steers much better with this long arm installed. Should make a comfortable tractor to handle. The tractor would have worked with the short arm, but it is much better with the change to the long one. A nice ride in the dark down the road was positive. Oh yes the lights work great too. May not win many pulls but will present itself well. Regards, Chris and Cheryl Edited by Sugarmaker - 02 Sep 2025 at 9:24pm |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3243 |
Thanks(1)
Posted: 03 Sep 2025 at 12:52am |
Looks very nice to me!!
Jgranat
Posted: 03 Sep 2025 at 7:39am |
Great job on the CA Chris, start to finish!!
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 03 Sep 2025 at 6:16pm |
Haven't been on here in a while. Boy, that CA looks pretty darn nice to me! Great job Chris. Congrats! Hope the ole girl pulls a good as it looks. It's to nice to get dirty! LOL! Steve@B&B
Sugarmaker
Thanks(1)
Posted: 03 Sep 2025 at 7:33pm |
ACinSC, Joe, Steve, folks,
Thanks guys! It's about time I got this old puller running and moving again! I picked up the rear wheel weights, which were cut into pieces that now weigh about 35 lb each. I am lightly sandblasting these weights, applying Rustoleum primer and then Rustoleum cream color top coat. Will try to get the PTO seal installed in the next day or so. The plan is to take the CA, our WD45, and Grandson Nic's WD to the local Albion Fair starting next week. The show at the fair may lead into the tractor pulls later in the week too. I took some time today to clean up the WD45. Regards, Chris and Cheryl |
Sugarmaker
Posted: 05 Sep 2025 at 7:48pm |
Guys,
I did get some additional details completed on the CA. Since its a pulling tractor and we do now have weights available. Then we need systems to attach and secure them. Heaviest weight are the side engine weights at 90 lbs each. The 12 IH rear wheel weights are approx 32 ish each, bolting to the IH rims. I fabed these 4 stud extenders to add the additional 4 weights to the rims after the eight were in place. Just tacked at this point.-+ I wanted a D ring on each side to attach the tractor to the trailer. These were from Tractor Supply and were to be bolted the a trailer. I blacksmithed the attachment bracket to fit the tractor. I was so happy with Rustoleum paint today. I sprayed a second coat of the cream on these and within minutes it went to cobweb texture. So much for all the cleaning and prep! This is 1.5 sq tubing where I was mocking up a tube to hold the 200+ lbs of sq , 15 lb weights we have. These flat sq weights can be stacked on these tubes. That should work. All that playing around will get us in the 3000 lb class if desired. Or allow us to add some weight if the Great grandkids are driving the CA. Regards, Chris and Cheryl
Edited by Sugarmaker - 05 Sep 2025 at 8:03pm |
plummerscarin
Posted: 05 Sep 2025 at 10:37pm |
That sucks about the second coat
If you read the label, there is a window for recoating times. Within 1 hour I think or wait 48 hours. Otherwise, what you've done looks really good |
Sugarmaker
Posted: 06 Sep 2025 at 8:11pm |
plummer.., Folks,
Heck of a concept reading the lable! Well I accepted the crinkle paint texture on the weights. New seal in place for the PTO: old seal tapped out with a large socket First day in bibs Hanging out: Weights added. The extensions worked well to secure the outer weights. Engine -2 side weights. These are awkward to install. That 180 lb on the front should keep the front on the ground?? Cleaned and added an exhaust flapper rain cap. Sand blasted several of the 15 lb weights for the back of of the CA. Regards, Chris and Cheryl
Edited by Sugarmaker - 07 Sep 2025 at 1:06am |
Sugarmaker
Posted: 08 Sep 2025 at 6:47am |
Folks,
So we are getting ready for our local fair. 3 years ago we purchased "Cheryl Ann" the rough little CA at this fair at the tractor pull. Owner Jack Farnum had this tractor for several years and pulled it at various local events, mostly in the 2500 lb class. The little CA held its own and usually finished better then mid way in the pack. Jack also had a WC that he hauled along with this CA. I guess I should call him and let him know the CA is up and going again. Here is our WD45 that Cheryl and I took it to display at the fair yesterday: Finishing up by cleaning the stacked weights on the rear of the CA: Running out of projects on the CA! " got on one of these CA's years ago and as I got on and off, I said to my son that "these were a young mans tractor"! Humm? Years later now we own one! Allis did not have ergonomics at the center of the tractor design. So as I thought about this, I saw there were steps that could be added to assist old folks like me to at least start to get up into the seat. The designs I saw attached to the torque tube of the CA. I liked the idea. So to be cheap I chose to look through my scrap stuff and try to build a step. I added my own design features (translate that into this was to cover up something or was just how the parts were that I found) as the design was prototyped. This cuts the step in half and seems like it may just work. Did I save anything if I count my time? Heck no! Did I design and build it out of nothing? Yep! Mesh from Allis grill to add non slip. Let's paint it cream, just because we don't feel like mixing paint! The step is not a bad idea. Will see how it ends up. Regards, Chris and Cheryl Edited by Sugarmaker - 08 Sep 2025 at 7:05am |
Sugarmaker
Posted: 08 Sep 2025 at 8:38am |
plummerscarin
Posted: 08 Sep 2025 at 11:51am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5264 |
Posted: 08 Sep 2025 at 12:29pm |
Had you made the step as a weight frame, you wouldn't have to admit you're an old fart that cant get on your tractor
Chris I have a couple of pictures that will show the difference between the CA an B/C front weight mounts. I just have to take time to process them from my phone into the computer. Edited by PaulB - 08 Sep 2025 at 12:31pm |
CA13414
Posted: 08 Sep 2025 at 8:14pm |
That looks spectacular. Awesome job. Love all the details like the personalized step! Congrats. Excited to hear how she pulls!! Dan |
Sugarmaker
Posted: 08 Sep 2025 at 8:47pm |
Paul, folks
Pretty hard for me to hide that I am now an old fart! I have seen the differences in shape of the CA vs B/C engine weights which is what I have. What I was concern with is the assembly that I had which I got that had a long arm, I believe was a "C" casting that did not have any side protrusions for a B/C or a CA to attach weights. Anyway, I used the junk I had and the weights I got with the tractor. They are in place. Do I need them, I have no clue, but in some track conditions I have seen the front of these be a little light. Regards, chris and Cheryl |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11379 |
Posted: 09 Sep 2025 at 3:07pm |
Yes a step on the front of the platform is a great ideal. I have one that someone welded to the cross bar for the break
Sugarmaker
Posted: 11 Sep 2025 at 8:55pm |
CA13414
Posted: 11 Sep 2025 at 9:01pm |
So sorry to hear. They really are such a great member of the family and..... always underfoot! :')
Dan |
wjohn
Posted: 13 Sep 2025 at 9:29am |
I always love seeing a Golden in your pictures now and then. Sorry to hear about Ruby.
Sugarmaker
Posted: 14 Sep 2025 at 4:39am |
Allis folks,
Thanks guys! These pups become part of the family real quick. She was a wonderful loving Golden. Here is the first picture of Ruby. Cheryl, at times, almost understands that Ruby is gone. She even said we should get another dog for her to play with. We are considering another pup. Man they are a lot of work. Regards, Chris and Cheryl |
Sugarmaker
Posted: 14 Sep 2025 at 10:19am |
Guys,
Some tractor stuff. May get my mind off the pup. NOT! Anyway some shots from the local fair we finished up tractor pulling on Friday and Saturday. A family event. All of us had fun. The WZ at the cement pulls on Friday we got 5th place. To much power spun the tires at 5 inches with 4000 lb on the boat. (this was the 3500 lb class) Gary on his WD, won the 3500 class on cement with a full 50 foot pull. Made it look easy! That evening I pulled in the Farm stock 3500 lb class and placed in third with the WZ tractor. Great grand daughter Cassie really like the tractors too! A little off topic but Daughter and her boyfriend Owen took the 32 in the parade while we got all the Allis tractors weighed in: The CA ready to get to the sled: I really cant complain on how it ran. We finished in 2nd place in the 3000 lb class behind a stout Farmall C. There were a dozen tractors in that class. FYI The 2500 lb class had 3 tractors which is where this tractor pulled most of the time. The front got a little light even with the 180 lb on the front. Grandson Mike on WD45 he finished 6th in a big class at 4500 lb. Owen Z pulled the WZ and got a third in 3500, and Mike pulled his cousins WD and got 4th in same class. Regards, Chris and Cheryl
Edited by Sugarmaker - 15 Sep 2025 at 7:45am |
Sugarmaker
Posted: 15 Sep 2025 at 7:46am |
Folks,
The CA and my first pulls with it: I did pull in low gear! Unlike Paul B! But this was a different experience and the CA is for sure not like pulling a WD series tractor. Engine never wavered at WOT through the pull. I was happy with the freshened engine work and the new cam. The track was just a little soft. The first pull I went 316 feet. They reset the sled and I pulled 208 and spun out. The brakes worked great, as I hugged the boundary line on the right side, and used the left brake to nudge the CA back to the left several times. Paint don't pull, but we looked pretty good, and I was not disappointed on how the old CA pulled! We may try the CA in the 2500 lb class on the final pull of the year. (Oct 11) And If I have a little help, we might just put the weights back on to pull in the 3000 lb class also. Then the weights would be back on the tractor for next year and I would have them out of the way. Trying to get some of the women in the family to get into pulling also. We will see how that goes?:) We now have drips of oil and rear end fluid from lots of places in the CA. Not unusual for these Allis tractors at this age and condition. I did not change or freshen everything inside the old tractor. Regards, Chris and Cheryl
Sugarmaker
Posted: 12 Oct 2025 at 9:23pm |
Allis Folks,
We took three tractors to our local tractor club pull Saturday. The CA, The WZ and The WD45. Three of us pulled. One guy on each tractor got to pull in two classes. The WD45 with Owen on board pulled first in 4500, then 4500 open and then 4000 lb class. Track was fairly dry and hard. He pulled in second gear. Spun out on loose dirt and really did not lift the front end much during the pull. Unfortunately Owen got caught speeding with the 4 mph speed limit. He would have placed in first. Next Mike pulled the WZ in the 3750 class and the 3500 lb class. He placed second in the 3500 lb class. I pulled the CA in the 3000 lb class and the 2500 lb class and placed second in the 2500 lb class. There were only three pullers in the 2500 lb class. We had a good time. I felt like a kid in the sand box. Trucks, trailers, tractors and friends and family playing in the dirt! Doesn't get much better. Regards, Chris and Cheryl Doesn't
Sugarmaker
Thanks(1)
Posted: 17 Oct 2025 at 9:31am |
Allis Folks,
Off topic for sure: Our new pup 'Duke'! We have not had a male dog for 30 years. After 3 days he is doing very well. Duke is an older pup , about 16 weeks. The last of a litter of 10. They saved the best for last!:) He is catching on faster than I can keep up with him. He likes Cheryl and is interested in what she is doing. Yes a few minor accidents, the getting into stuff too. a little whining when kenneled at night, but quiet the rest of the entire night. Trying to get him more used to the kennel. Our cat, Lucy, is mad, she has to train another pup! Regards, Chris and Cheryl
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4264 |
Posted: 18 Oct 2025 at 6:00am |
Good to see you got another golden Chris! They are such fantastic creatures.
Sugarmaker
Posted: 22 Oct 2025 at 2:52pm |
Mike, folks,
No regrets yet on the new pup. Duke does all the puppy stuff for sure. But I like his disposition a lot. We picked up the hemlock Monday. Nice stuff. Just realized it is planned on the wrong side. Two options: take it back and have them plane it or run it through to my small planer a couple times. I will probably do the latter, as its here and that would give me another project. 48 Pcs 8 foot long, 10 PCs 12 ft long. The D14 is in the shop for electrical review. It just doesn't start like it should. click click then it spins over intermently. I would like to change it to 12 volt. I have had really good luck with the denso one wire alternator system. The rebuild lift cylinder seems good. Bled it as I filled the hydraulic fluid. No leaks! Trying to get things ready for winter. I never found a patina left side cover. So I may just order a repro from Stieners at some point. I just got a used stair lift installed in our garage, if Cheryl needs one in the near future? Heck I may need one in the near future!:) Friends gave it to us and it fits just right in our house garage stairs! Amazing how things come together! I knew nothing about them. It is a Acorn brand made in England. So I had to replace the batteries, make some adjustments and replace a couple corroded ends on battery terminals. I went the cheap route and ordered the batteries of eBay, about 20$ each. Regards, Chris and Cheryl Hope things are good in Orange land!
Sugarmaker
Thanks(1)
Posted: 25 Oct 2025 at 6:42pm |
wjohn
Thanks(1)
Posted: 26 Oct 2025 at 12:06am |
Sugarmaker
Posted: 26 Oct 2025 at 9:30pm |
wjohn, folks,
Yes your right it could be worse! No room for more orange here! Especially the big orange! :) Regards, Chris and Cheryl
Edited by Sugarmaker - 26 Oct 2025 at 9:31pm |
CA13414
Posted: 28 Oct 2025 at 7:54pm |
Page <1 17181920> |
