Allis CA |
Page <1 16171819> |
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8509 |
Mike, Folks,
A little more of that too! I did leave the dash box in the lower position. I couldn't get the 5/16 nut on the back of the box. The Battery box bracket was in the way. Remember this is only a Clean, Refurb, and Paint project. I have had the gas tank assembly on and off several times. I forgot I needed to run the wires in the tool box area. Headlights and tail light wiring is what's left to complete. Regards, Chris
Edited by Sugarmaker - 24 Aug 2025 at 12:44am |
Guys,
Almost there! Tonight I completed the spark plug wires. Primed the oil pump. Got a new battery from Walmart. The old battery had been used on my electrolysis tank and it is pretty hard on them. It would spin the tractor and then die. Took a couple tests to determine it was not good under load. Oil pressure is at the N in normal with our running yet. Just cranking. I tried the hood. Looks like it will be ok when finally fit. Busy day tomorrow but may try to start the CA? Cheryl's birthday is Tuesday. I would like to have it running. I did try the lights and they worked. Some other shots: I know the cable colors are not correct. But that is what NAPA had. Luan cover to keep lid off the terminals The silver bullet Cheryl helping prime the oil pump. Crude set up but it worked! Regards, Chris and Cheryl
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3911 |
Man, that looks great.Nice work!
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2970 |
I agree, good work!!
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1784 |
I noticed the floor pan didn’t have a hand clutch lever notch. Did it ever have a hand clutch?
Guys,
Thanks! Sparky, I welded in a sheet metal patch where the hand clutch was. I thought someone might get a small foot in there. I added some gas and friend John came over this morning turned on the gas, flipped the key and pulled the starter rod. It fired up. We weren't there. Got out to the shop in a half hour and started it several times today. Even took it out around the shop. All gears seemed to work. Brakes worked very well! Steering not great, stiff. Should work fine for pulling. Oil pressure was very good. Had a minor problem with the side hood bolts being too long. My fault. fan blades hit them and luckily did not do much damage. Got that fixed (Dodged a bullet on that fan thing, could have been way worse!). It seems to run pretty well. Have some oil coming out of the short hose from the air cleaner to the carb? Not sure what the cause is? Also have a leak at the upper edge of the hose from the water pump to steel tube. Pictures are coming! Tomorrow is Cheryl's birthday! Hoping to get the decals on tomorrow too. Warmed it up at different rpm's, pulled valve cover and set valves to .012 inch. I repainted the hood strap and the oil filler cap this afternoon and installed them this evening. The paint was too light, ok its not going to be perfect. Went around and touched up a bunch of areas that have been light and or missed or scuffed. Regards, Chris and Cheryl
Edited by Sugarmaker - 25 Aug 2025 at 8:53pm |
Check and see if you’ve got too much oil in the oil bath air cleaner.
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10894 |
That would be my thought also.
Looks great, showroom ready.
CA13414 ![]() Silver Level ![]() Joined: 25 Feb 2024 Location: Nebraska Points: 358 |
Awesome job! Looks great!!
Your oil pressure looks great!!!
Dan |
Guys,
The continuing saga of the CA. I pulled it around to the other side of the shop. It started to run rough, like running out of gas. It was struggling for sure! Got it back in the shop. Retorqued the head and checked the valve lash again. Took the carb off and cleaned it again, put more gas in it. Removed sediment bowl and cleaned out the light stuff in the glass. Still did not run good at all. Pulled each plug wire while it was running and the very rough running did not change at all. Checked the valves again. Had run out of things and was afraid I had put something together wrong and it was coming apart! So I called a good friend since day one of first grade a Allis guy and a good mechanic too. He said the problem might be the condenser. I had just put a new one in. We talked about getting the rods in wrong on these engines. I drained the oil and was ready to pull the pan to check rod location/ direction/ offset. I could not remember checking that. I looked back through my pictures and remembered that I just marked the top of the pistons with a arrow and a number. I had never taken the piston and rods apart. So our son Eric was over for his moms birthday today and he was walking around the tractor listening to the story of the CA running rough all of a sudden today. And also what Ted had said. Eric said do you have another condenser? Yep, I put it in dumped the oil back in. And Fired it up. It ran fine! I could not believe it. I have never had a condenser fail like that. Learned something today! Eric took it for a ride down the road. He found his birthday numbers in a casting number on the side of the tranny!:) Maybe the decals will jump on the CA tomorrow? I want to get some sulfur additive for the cam break in. we still need to get some time on the engine in next two weeks. Pull coming up at our local fair in mid September. Next is to clean up and paint the weights needed to get to 2500 lbs. Maybe even the 3000 lb class. Regards, Chris and Cheryl
Edited by Sugarmaker - 27 Aug 2025 at 5:59am |
Glad it was an easy fix!
Been reading about these new condensors going bad fast.
Guys,
I called Sandy lake and ordered a cork valve cover gasket. This OEM black rubber gasket thing doesn't seal at all!!! Oil running down both sides of the engine. I will have to take the hood off and on again! It really is a two person job on the hood install with the headlights on but loose. I also ordered a condenser for a mag. Said to be a better condenser?? Today I pulled the alternator and tried to goop up the leaking hose from the water pump, will see how that worked? Pulled the carb again and re set the float to close the needle valve sooner. Grandson and his boys came up and drove the CA a little. Seems to be running ok! Decals went on this morning. I don't like this mylar type as well as the single letter vinyl. I will try to take off the hood and put the new cork valve cover gasket on. Does anyone glue these down?? Will also put the new condenser in the distributor. Have only been setting the timing by ear, turning the distributor till it sounds happy. It steers very firmly! No wobble in high gear on the road. Will work fine as a puller! Regards, Chris and Cheryl
Edited by Sugarmaker - 27 Aug 2025 at 8:09pm |
Nice and looks great. Really love how it looks with the Decals.
Per "Steve in NJ," setting it by ear is the right thing. Dan Edited by CA13414 - 27 Aug 2025 at 8:26pm |
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1289 |
I was curious as to how that long arm/short arm combination would work
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 438 |
Tractor looks great, for gaskets I usually use 3M yellow emblem adhesive or as we call it around here gorilla snot. Use sparingly only on the side you want to hold steady and easiest to clean off if ever needs to be removed. Dries pretty fast and is only there to keep gasket from moving, let the gasket do its sealing thing.
Allis folks,
Thanks for the support on this CA project. I took it for a 1/2 mile ride. Yep steering is stiff but manageable. Short arm, long arm is not the best combo. Valve cover gasket seems to be finally sealed up. On the adhesive. I used trim adhesive to hold the material between the hood and gas tank. Worked well to not have that flopping around. Putting the sprung out hood on is really a two person job. Added some sealer to the coolant to slow down the leaking hose out of water pump. Some improvement to that leak. I removed the Zenith carb again and adjusted the float pontoons lower, hopefully shutting off fuel flow sooner. (A lot of Allis tractors must have the fuel shut off do to carb leaking). I have not tested the float adjustment, but I am sure I will forget to shut off the gas at some point. The CA starts very well. No choke or throttle required. Sounds good a all throttle positions. The replaced cam doesn't seem to have any negative changes to the sound/or performance of the engine. I did get the rear wheel weights cleaned up and painted the light cream color of the rims. Those four split IH weights should put the CA at about 2500 with me in the seat. Regards, Chris and Cheryl
Edited by Sugarmaker - 28 Aug 2025 at 7:01pm |
I like the headlights.
Wasn't sure if I wanted to install them on our CA. After seeing your CA, I think I will go ahead and sand blast the old lights and add them. Thanks! |
CA13414,
I mentioned its one of my goals to have lights working on these. These came from Alex on the forum along with the tail light. They look correct and were ready to go. (side note maybe I will get at the D14 next to at least get the headlights working and maybe convert it to 12 volts also! This CA starts instantly! So nice!) I got the wheel weights on the rear. Thinking of getting the other set of rear IH weights cut in half too? Would be much easier to handle for sure! I need to see if my machine shop has an easy way to cut these IH weights. Would need another 500 lb. The engine weights plus the 2 more IH rear weights and a bunch of my 15 lb weights would be needed. Still have the engine weights to wire brush prime and paint PO#1. Regards, Chris and Cheryl Edited by Sugarmaker - 29 Aug 2025 at 8:03pm |
Guys,
Continued shake down of the CA. I did take the alternator off again and took the leaky hose connection off the water pump outlet. Put some silicone goop on the surfaces. Reassembled and it still had a small leak. I put the sealant in and after running several times and coming up to near 170F. Most all of the dripping from that minor problem are gone. On to the next. I found that the oil leak at the rear was from seepage at the PTO shaft. I removed the PTO cover/ guard. Cleaned the shaft where there was a slight grove at the seal location. The seal was very dirty but intack. I cleaned the seal up. Then removed some of the shims that space out the cover. The idea was to move the seal to a slightly new position on the shaft. Well removing the shims tightened up the rotation of the shaft. But it also stopped the leak! So I think I will zip tie the PTO lever in the off position. I dont think we will need it for pulling. But the CA would be a great tractor on our buzz rig someday if needed. When I pulled the carb and reset the float, I thought that might help if I left the fuel on? Well I did and that did not stop it from flooding out the carb! I did weight the engine weights and with the hard ware each would be 90 lb. Took the CA down the road in 4th gear and it runs good. Some minor steering moves to keep it headed straight. I think the incorrect steering arm makes it turn very quick, checked this at low speed only!:) Hope things are good in orange land! Regards, Chris and Cheryl
Yup. The overall steering ratio will be about half of the original, so each degree of steering wheel movement will produce about twice as much change in direction.
Les,
Yes that sounds about right on the quick steering. The reason I wanted this front end retained was for the side engine weight attachment. We got that and then quick stiff steering as a side benefit. It will probably be just fine for what we are doing with this old CA. Weights: Edited by Sugarmaker - 30 Aug 2025 at 8:17pm |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5102 |
Had you changed the steering casting to the correct CA casting, you could easily attached the B/C side weights the the CA front steering casting by just using s longer bolt.
What you can't do is put the CA side weights on a B or C tractor. The CA front casting would also give you more options for front weights. I have some small cast weights the perfectly match the cultivator front mount holes. If you remember, I have a CA steering casting I would have given you had you picked it up or met me at one of the pulls I go to, or I could have sent it along with a buddy that went to a truck show in NE Ohio.
Paul, Folks,
Thanks for checking on me. I had forgotten about the steering casting that you have. That's an idea for sure. I think I got long arm casting but it did not have the lugs on the sides for the weight bushings to be attached. Maybe that was from a long arm C?? I will have to look back on that. BTW the reground cam seems to be running fine. I got to thinking on this long arm/ short arm thing. And Ok I am old and somewhat brain dead. So the gerble jumped back on the little wheel in there, and I think I still have that long arm, no wheel weight lugs, upper casting. I never thought about taking the long arm and its shaft being removed from the casting. Humm. Someone had to put it together, That arm did not grow in there. So went out in the vast warehouse and found said casting assembly. Proceeded to remove the long rod assembly. I have no clue why I did not consider this change earlier in the project?? Will it work? The castings have a different length protrusion of the casting where the steering rod goes in. Will that be an issue?? I done think so?? Or I could put a spacer over the long arm shaft?? So probably someone mentioned this change before and I missed it and got off on another tangent?? Open for comments. Regards, Chris and Cheryl
Edited by Sugarmaker - 31 Aug 2025 at 8:12pm |
Folks,
After a little nap I remembered the engine weights. Are these all the same or is there a right and left hand weight? I have two that have a -2 cast into them. It seems they both fit even though they are not opposite hand. Doesn't seem like something that would be engineered like that?? Regards, Chris and Cheryl
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2204 |
Chris, Brian Ahart's site seems to indicate that the one without the bevel might be earlier? However your weight without the bevel has a -2 in it, it sounds like, instead of the -1 shown on Brian's site. That is probably a revision number but I don't understand why they would have made a -2 both with and w/o the bevel, if this is the case.
I have a set of inside rear wheel weights for a C if your interested, here in Ohio. Tom
wjohn, Folks,
Both of the -2 versions have the bevel as shown in Brian's picture. Might not be clear in my pictures? The weight has to be inverted to fit the opposite side of the tractor. So I guess as others have noted I have 2 of the B/C weights with the AM3315-2 Like the rest of the tractor mismatched stuff through this unit! The weights look like they will fit and work on both sides of the engine. Thanks guys for the leads on extra weights available. A friend may be looking for some of these for his CA tractor. So I started on the front steering prototyping of the CA steering arms. This may work? I almost have the shaft out of the gear in the casting that is on the tractor. This short arm is a different shaft and gear design than the long arm version. The short arm gear is keyed on a straight shaft. It has a typical Allis set screw with a lock nut like the one holding the starter in place as an example. So I have the shaft almost out of the gear. Yikes it is really happy there! Hope to get that apart tomorrow. Then I will attempt to install the long arm and its gear, key, and lock nut assembly. If it doesn't not work, well I will have learned a little more about these tractors. Regards, Chris and Cheryl
Edited by Sugarmaker - 01 Sep 2025 at 9:16pm |
I have 2 complete sets of CA rear wheel and engine side weights for $700 a set.
Page <1 16171819> |
