Allis 426 injector help needed please.
david.bz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Topic: Allis 426 injector help needed please.
    Posted: 12 Mar 2012 at 9:25pm
Hi there. I have a compression leak at my #2 injector. It is in a combine. I pulled the injector today and am wondering how to pull the copper compression washer that goes underneath the injector? Any help would be appreciated.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 9:36pm
Use a 5/8 fine thread tape. Screw into copper ring and pull it out.  MACK
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:05pm
Macks right on there thats what we use some times a little oil or penatating oil will help loosen it up Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:06pm
Thanks Mack. Will try it tomorrow. Is there also some type of a replaceable oring in the sleeve that the injector sits in?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:30pm
No oring,  there is a rubber sleeve on the top of the injector to keep water and debris from getting between the injector and the bore in the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:43pm
Hey Skip! Could a guy stuff some silicone around the top as a make shift rubber sleeve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:54pm
I dont see why that wouldnt work, it would be better than those phony foam sealing rings they used to use!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:11am
The reason I asked about the oring is because when I was cleaning yesterday I felt, at about 2" down the hole, something that felt like a rubber oring in a seat. i figured it would be to keep water etc. from going all the way down and ceasing the injector inside the head.  I happen to be in the jungle and my manuals haven't arrived yet for the combine and engine SO a really big thank you for your help!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 2:04pm
Well, it worked!!! Not the way I had envisioned it but it worked! I went to pull the injector washer this morning and the tap didn't seem to want to work. I went down with a pick and couldn't pull the washer. I determined that there was a washer and if Mack says that the tap works then some how it WORKS! went back down with the tap and a hammerConfused. Yes I had visions of all kinds of stuff ending up in places they are not suppose to be. softly I tapped the tap. Still nothing. OK, what now. Well I decided that if I was going to have to pull the head I may as well have a good reason. BANG! turn with 3/8ths wrench BANG! Oh OH! something is on the end of the tap.
Blew everything out with compressed air. Couldn't find the missing piece. BUT, good news is that upon further examination, the break isn't a new break.
Thanks again for you help.
From the jungle.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 9:51pm
Well, just to finish off this experience, couldn't find the correct sized copper washer today.  Oh well, here in the jungle there is something called creativity. Sometimes it works, sometime it doesn't. I found a washer that was too small and decided to stretch it. Put the injector back in. Started the engine and waited. 4 injectors now leaking fuel. Re torque fuel return lines. AOK. Works. No blow by. Awesome! Get to harvest some edible beans tomorrow. Really excited about how it works. Thanks again!
