Allis 3300 disc
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 3300 disc
    Posted: 10 Oct 2016 at 4:41pm
Are these discs any good? It is a center fold. blades are like new and new bearings. It is 18-20 feet wide for $2500
How much horsepower to pull this disc?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:58pm
I owned a centerfold Deere I will never own another centerfold disc again.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:01pm
A 3300 is a heavy cutting disk. Center fold or not your gonna need a few ponies and some weight to pull it. The last disk you were looking at with a few blades off would pull easier and do a better job finishing.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:15pm
I wouldnt put less than 130hp on it to pull it right
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 10:01pm
Victory.....deeres center fold was crap! AC's was a good one, I have one and it's the best disk I've ever owned! mines a 2500 I think
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 10:02pm
Unless your fields are nearly flat as a pancake I would not recommend any centerfold disk I don't care what color it is.   You get on some rolling land with one of those things it will make such a mess that you will practically need a dozer to smooth it out.
They work great on flat land though.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 10:25pm
Father in law had 1. Behind a 7060. Was a dirt turning machine. He used it on side hills and flat ground. I did not notice a big problem on flat or steap side hills. I planted corn behind him disking. This has been over 30 years ago and memory is very bad. If I had the horse to pull it I think I would give it a serious look see. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 12:15am
I have flat, gently rolling, and goat hills here, and  the AC centerfold did really well, cuz it flexes. it was designed well!
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 8:58am
Never had a problem with the 2500 center fold disc on hilly ground
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 6:45am
We don't have a single problem with our 2500 center fold on hilly ground.  The little bit of flex that it has is working here for us.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 8:05pm
I have a 3300 center fold disc that I pull with a 7060 with duals.  If you're cutting very deep at all I wouldn't want less tractor on it.  Getting it level is the big problem.  It can ridge so bad you'll have one heck of a time leveling the field.  Very heavy frame.    You're right about John Deere single folds.  Our tenants are all Deere except for their disc.  It's red.  They used to have a JD single fold and quit using it.  Parked it in one of our sheds.  Went out and bought a Case IH.
