Allis 200
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200
    Posted: 27 May 2012 at 6:58am
Good Morning Gents:  Opinions please on the 200, one near me - nice shape.  2900 block very clean.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 9:24am
Good tractor.It is  like the series III 190`s,  make sure it don`t jump out of any gears.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 9:48am
Burgie: Assume the third gear is the one to check?  This 200 is an open station with a heavy duty three point hitch.  Would be using this on a 25 acre field for plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 9:50am
Usually 3rd but check them all when going down hill.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 10:45am
Heres my experience with a 200 tractors ; they are good machines but the gear jumpout seems worse ; 3 rd gear especially ; i,ve redone 3 Powerdirectors this spring , all on 200,s ; all the same hi side broken clutch plates , an ole AC mechanic once said to put them in 3 rd gear , low side , open it up and stand on the brakes ; it should kill the engine providing the brakes are good !! Also the brakes ;;;;; if they are adjusted correct , they are great , a little out of wack and they suck , i,ve found that lot of the time the brake housing fills up with dust , dirt and brake dust and that screws them up ; check the POWERDIRECTOR linkage close ; it has to be tight ; a little play and the cluthes slip and bam ;; major slipping ; good luck , most of these are priced right 2500-4500 and make good tractors !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:35pm
Hello Doug and Burgie: Will check those items out.  This one has about 5300 hours on the block - appreciate your insights and thank-you! Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:53pm
Another thing , see if it been overhauled, meaning engine ; these engines seemed more suseptable to the electrolicess issues ; the sleeves get pits in them eventually leaking water into the clyinders
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 5:33pm
Great machine!!  check the things said in the post but we have run them and have had good luck with them.  If they do need work they are easy to work on, Parts seem to be easy to get yet.  Good luck!
Andy
Andrew Gubbels
Gubbels Restoration
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 5:48pm
We had one on the farm it was a good machine we worked the tar out of it. The late ones are the tractor of my choice, They have better brakes and an updated pd . And with what I do to the one I have now and it stays together have to be ok.
This page was generated in 0.067 seconds.
