Allis 2000 monoframe differences (upright)
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Allis 2000 monoframe differences (upright)
    Posted: 16 Sep 2016 at 6:36pm
Does anyone know what the differences are in the monoframe 2000s. Looking at one. It had longer beams (uprights) that the bottom bolts too, but four of the five have been changed to shorter ones. How hard would it be to find another short upright?
Thanks
Adam
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 9:10pm
Not sure but shouldn't be too hard to find.  They made one that was 28 in clearence and one that was 32 in.  I just changed on from hyd reset to spring trip by killing one, it appears the hyd reset was 32 in and spring trip 28.  Worked good but had to run the rear as deep as it would go to get depth in the back.  Looked at my other ones and there was a difference in the geometry of the tail wheel so may have to switch that before next year.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 7:34am
maybe this matters and maybe not but the mono-frame is bigger as there were more bottoms on the unit. we have a 6 bottom base and a 4 bottom base is how I found this out. I think the AC mono frame plows are a little hard to find parts for.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 8:00am
They are good plows. I have an older 28" clearance 5-14 & a newer 32" clearance 6-18. The older has shear pins & the newer has spring resets. Hydraulic resets were optional. The rubber flex mounted coulter (cutters) was another option.
Sometime back on this site, a former AC employer shared how engineering used a particular welding method of the mono-beam frame-hitch segment. Initial common welding resulted in warpage? So a jig or method was used to keep proper alignment.
