ALLIS 190 AND WESTENDORF WL 27 |
tractorman ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Nov 2011 at 5:12pm |
hAS ANY BODY GOT EXPERIENCE AND OR PHOTOS WITH MOUNTING THE WESTENDORF WL27 ON A 190 ?. i AM GOING TO DO IT AND WESTENDORF SAID THEY DON'T HAVE A KIT OR PLANS. Okay iam not really doing it but have a very competent welder assembler mechanic that will do it. tRACTORMAN
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1474 |
I'm pretty sure Westendorf did make brackets for a 190. Maybe they quit because of low demand. I know for a fact they make them for a 185. My uncle has a WL 27 on his 185. I would say a set of 185 brackets could be made to fit with minimal modifications.
StewartMD ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Emmitsburg, MD Points: 314 |
Our Westendorf TA26 loader was off of a 190XT, we have it on our 185, everything was the same except for where it bolts to the rear axle, we had to make a spacer out of tubing and drop it down with some plate steel. The last time I talked to them they could make the brackets for just about any model/any brand, but I'm not sure what it would cost.
Edited by StewartMD - 14 Nov 2011 at 8:16pm |
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
but but this one is coming off a deere 3010, could it be a lot different ? tractorman
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
we got a kelly 800 off a 1650 oliver for 150$ when i called kelly mfg they said they csnt sell me the brackets cause the loader was on an oliver??? figure that one out we had a local steel shop make everything we needed and it works fine
190XT,D17and 7045
I was under the impression that you were wanting to buy the correct brackets but Westendorf didn't offer them. If it's coming off a JD, there could be quite a bit of bracket modification. |
I would suggest getting a ballpark price from your welder, and getting a quote from Westendorf, if it comes from Westendorf you will know it will be built heavy enough in the right places.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29805 |
I, my Dad and a neighbor modified a CaseIH 2250 off a 3220 (way too little of a tractor for the loader) to fit my D19. Works good. Well, as good as a D19 would ever work with the standard hydraulics. Took one weekend with a lot of BS sessions and some beer.
Wink I am a Russian Bot |
