Allis 180 gas - engine doesn't want to shut off... |
allispicker ![]() Silver Level ![]() Joined: 29 Sep 2011 Location: Iowa Points: 160 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jul 2018 at 9:36am |
My 180 gas tractor start and runs well, but the issue I'm having is that when I turn the key off, the engine acts like it wants to stop but will stay running at 100-200 rpms and I have to put it in gear and hold the brake to kill the engine. Any ideas?
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34259 |
must be carbon in the engine... Cleaned your spark plugs? Maybe try setting low idle screw lower? Probably carbon on the exhaust valve. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21512 |
Your engine is "dieseling" ?????????? Low idle must be at 400 RPM and you have to idle it that slow for maybe a minute before shutting the key off.
What is "dieseling" and how do I fix the issue? I have never had this problem with any of my other gas tractors. I'll try some new plugs as well.
Thanks.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24415 |
dieselling is when a gas engine has so much carbon buildup in the cylinders that you don't need a spark to ignite the gas/air mixture. Usually running the choke too much, over time allows the buildup to occour. Best solution is to pull the head and scrape the buildup off.
Thanks for the information, I'll work on pulling the head.
Jump right in and do the worst possible scenario !! Let's pull the head before going to AC Delco 44XL spark plugs or making SURE the low idle is at 400 RPM and before we allow it to idle slow for 60 seconds before shutting off the switch and before it has maybe a better grade of gasoline ?? Yup. That's what I would definitely NOT DO is yank the head.
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 706 |
Yeah, usually its a piece of carbon that gets so heated up and retains that heat so that it continues to ignite the gas after the spark is shut off.
Pulling the head is the best way, certainly, but you could try any number of way to try to reduce the carbon, including something like Seafoam or even water....very carefully. [TUBE]KFtp_jmLF3k[/TUBE]
Edited by HoughMade - 17 Jul 2018 at 12:11pm |
1951 B
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 1022 |
I agree with the dr. if those don't work then put on a dyno and apply load slowly over time to burn that stuff off. don't just go to full load right away as it will detonate. another option is to mist water from a squirt bottle in the carb when running. this will cool the carbon and it will likely flake off however it could stick a chunk in a valve seat and lead to a burnt valve.
@Dr. Allis - great perspective! I'll try the quick/easy/cheap fixes first
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9720 |
An excellent product is to remove internal engine carbon deposits is KREEN from KANO Laboratories in Nashville, Tn.
I use BG products and SeaFoam but like the results from KREEN the best. KANO Labs is the maker of KROIL.
Edited by Clay - 17 Jul 2018 at 2:12pm |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
The last thing I'd do is pull the head. BTW I gotta say the good dr has a way making his point.
Wink I am a Russian Bot |
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3966 |
First pull and clean the plugs. After that a Seafoam treatment. Run at fast idle mist it with Seafoam till it quits. Let it sit a hour star it and run it hard. I had a C that was very bad I added one gallon diesel in five gallons gas and mowed the yard. It ran hot the fist time I've ever seen the temp guage actually make it to operating temp and spit out lots of carbon bit from the exhaust burned a few holes in my mowing shorts. After that it ran like a dream.
I would also check timing. Advanced timing can cause hi cylinder temp and burn pistons. MACk
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4987 |
In days gone by disreputable gas stations would set the idle a bit high and mess with the timing to make cars diesel like that. Their answer to the problem was high test gas. Do a proper tune up by the book specifications and let it cool a bit at idle before turning the key off, and I’ll bet your problem goes away.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Back in the early days of smog control dieseling was a common problem. They even installed anti-dieseling solenoids on some cars. I believe timing was the cause. Some cars were timed to fire AFTER TDC. Firing at 0 degrees was common.
CALEBnOK ![]() Orange Level ![]() Joined: 12 Nov 2011 Location: Oklahoma Points: 618 |
Unwire the alternator and see if it still runs on
