Allcrop 60 Draper???
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Topic: Allcrop 60 Draper???
    Posted: 25 Apr 2012 at 8:44am
I finally got around to messing with my Allcrop yesterday, but I can't figure out how to tighten my main draper.  I don't have a manual to look at either, so if someone could uplad me a picture to show me, it would be greatly appreciated as would any help. Everything else seems to be working fin on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 11:04am
There is a lever on the lower roll that tightens the canvas.  If tightening that doesn't work, then you will have to loosen it and feed more canvas through the splice where the canvas comes together, so it will tighten with the lever.
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 11:47am
I'm trying to remember but I think the upper draper had to be flipped up and the canvas fed through the slats joint farther and tightened. When the draper was put back down, it would be tight enough to run. Ted's right on the lower draper but I really think there was no lever on the upper draper. I could be wrong....it's happened before and I don't have a machine handy to check any more.
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:18am
Yes, ther upper draper is working fine by flipping it back as stated, but the levers on bottom of lower one aren't getting it tight.  I will try the this tip though, thanks and i will let know if still need futher help.
This page was generated in 0.035 seconds.
