All Crop 60
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: All Crop 60
    Posted: 16 Apr 2012 at 9:41am
Got the All Crop home Saturday. Seems to be in good condition. Got most everything freed up. Had to make one new clean out door. The combine has one patch in the area just above the header. New tires! Will have to rebuild the bottom of the Scour Clean as mouse nests rotted it out.  Two questions;
1) Anyone have a Scour Clean screen in good condition they want to sell?
2) Do I have to remove the drive gear at the bottom of the unloading auger to remove it? The flightling should be replaced.
I remember my Dad commenting that these things have a thousand grease zerks. Now I know what he meant!
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 11:00am
1) not I
2) yes. (fun)
www.allcropharvester.com
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 11:29am
If you don't have one it is wise to get a manual. It will show all the grease fittings.
DO NOT REPEAT NOT GREASE THE SLIP CLUTCH!
Just be sure it is not frozen. Don't know why they put a fitting there.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 11:34am
Thanks Bill! I likely would have greased the slip clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 11:42am
Where is the serial number on the 60?
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:43pm
Good Luck!
Bill Long
LOL!  I made that mistake last year!!  Brakecleen sprayed on it while it was slipping cleaned it up.  Won't make that mistake again!
