All Crop 60
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=49070
Printed Date: 26 Aug 2025 at 5:11am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: All Crop 60
Posted By: KenBWisc
Subject: All Crop 60
Date Posted: 16 Apr 2012 at 9:41am
Got the All Crop home Saturday. Seems to be in good condition. Got most everything freed up. Had to make one new clean out door. The combine has one patch in the area just above the header. New tires! Will have to rebuild the bottom of the Scour Clean as mouse nests rotted it out. Two questions; 1) Anyone have a Scour Clean screen in good condition they want to sell? 2) Do I have to remove the drive gear at the bottom of the unloading auger to remove it? The flightling should be replaced. I remember my Dad commenting that these things have a thousand grease zerks. Now I know what he meant!
------------- '34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Posted By: TomYaz
Date Posted: 16 Apr 2012 at 11:00am
1) not I
2) yes. (fun)
www.allcropharvester.com
------------- If its not an All-Crop, it all crap!
Posted By: Bill Long
Date Posted: 16 Apr 2012 at 11:29am
If you don't have one it is wise to get a manual. It will show all the grease fittings. DO NOT REPEAT NOT GREASE THE SLIP CLUTCH! Just be sure it is not frozen. Don't know why they put a fitting there. Good Luck! Bill Long
Posted By: KenBWisc
Date Posted: 16 Apr 2012 at 11:34am
Thanks Bill! I likely would have greased the slip clutch.
Posted By: KenBWisc
Date Posted: 16 Apr 2012 at 11:42am
Where is the serial number on the 60?
Posted By: Rawleigh
Date Posted: 16 Apr 2012 at 12:43pm
Bill Long wrote:
If you don't have one it is wise to get a manual. It will show all the grease fittings. DO NOT REPEAT NOT GREASE THE SLIP CLUTCH! Just be sure it is not frozen. Don't know why they put a fitting there. Good Luck! Bill Long |
LOL! I made that mistake last year!! Brakecleen sprayed on it while it was slipping cleaned it up. Won't make that mistake again!
