Air in sediment bowl
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: Air in sediment bowl
    Posted: 21 Jun 2012 at 9:04am
I am seeing a little air in my sediment bowl '39 B. No gas leaks. What could cause this?
Suggestions?
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 9:20am
There is air trapped in the bowl from when you last installed it.  Loosen the bail, allow some gas to run over the top of the glass bowl (forcing the air bubble out), and then tighten the bail.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 9:32am
Thanks
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 10:20am
If the tractor is running well don't try to fix what isn't broken. Don't ask how I know!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 9:47pm
Will never hurt anything.   MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:54am
Mack and nella are right also it's one sign that your needle valve is in good shape.
