AD17 Snow Blower
MarkSaintPierre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkSaintPierre Quote  Post ReplyReply Direct Link To This Post Topic: AD17 Snow Blower
    Posted: 22 Jun 2010 at 5:29pm
Could you tell me what snow blowers are compatible with an Allis D17 ?
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:07pm
none unless you have a 3pt.   6ft is the best size for a D17
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:35pm
There are snap couple adapters out there that would let you hook a 3 pt blower up to a WD or 45.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 7:20pm
Mark is a friend who recently got into the AC world. He's looking for suggestions on brands/models - as well as whatever might be available in South Dakota! His D17 has a 3-pt hitch of some sort - have suggested to him that he post a picture, also. TIA.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 7:33pm
We ran a 7 foot on our D17 with a 3 point adapter back in the 70's/80's...was too much in drifts and you had to slip the PD (hand) clutch a lot.  Works much better on my 180 now. I agree 6 foot would be just about right.  Spin the rear rims all the way in and you'll be inside the cut.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Fidel513 mo. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fidel513 mo. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 8:42pm
i have a john deere 6ft i used on my d17 series IV. planning on selling it. don' snow in st.peters mo.
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 9:40pm
I run a 7' IH 80.  I like the 7' width as it makes turns easier.  Otherwise the outside front tire is in the snowbank on corners (assuming it's a wide front).  We get alot of snow but it is light and fluffy - your results may vary.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 10:28pm
I use a 7' Lorenz on my D17 S1.  Have a 3 pt adapter thingy.  No problems, although according to Lorenz the D17 is too big for the blower.  I kinda scratched my heed over that one until I accidentally read the manual.  Larger tractors mean a steeper angle on the pto shaft.  So I run mine with the shoes all the way down.  No worries.  Also tried grade 2 shear bolts - too soft, need grade 5.  Accidentally found that in the manual too.
cheers,
Creek
