AC6089 Block Heater Remove and Replace
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Topic: AC6089 Block Heater Remove and Replace
    Posted: 25 Nov 2021 at 2:38pm
I recently purchase an AC6080. The Block heater is bad and I purchased a new one from Countryside Tractor.  But, due to the design of the pipe to the oil cooler I am not able to remove the old Block heater. Any suggestions?  My first thought is to cut the tube going to the oil cooler and then run a rubber hose form the new heater to the oil cooler (the new heater is a slightly different design in that it only has a short stub for the oil cooler line).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 7:32pm
Yeah Ive dealt with those and the last thing I thought was - do i gotta split this thing to get a new one in , lol- quite a design- i have cut the tube and used as much of it as i could then used high temp rubber hose to connect,
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 7:28am
Cut old tube off and use part of it to fit to oil cooler hook up with new hose in kit
This page was generated in 0.131 seconds.
