AC Planter Question
Message Reverse Sort Order
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Topic: AC Planter Question
    Posted: 29 Apr 2019 at 8:00am
...and never, ever back up with the planter in the ground...
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 6:51am
As already mentioned, keep moving forward when raising or lowering planter.
This also applies to planter with disc openers.
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 6:46am
Be moving forward when you let it in the ground and keep moving when you raise the planter out of the ground.Don't stop with the planter on the ground.
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 6:25am
It was with ours when it the ground conditions were not quite dry enough. When planting we tried to keep it moving other than stop and put it down. Seemed to help some.
WD D17D 170 190xt 190xtIII 200 7020
Garrett2006 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 5:54am
What keeps the planter shoes/seed drop tube from clogging with dirt? Or is this common problem with old row planters with shoes instead of disc openers? Thanks
This page was generated in 0.328 seconds.
