AC 8010 A/C
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: AC 8010 A/C
    Posted: 19 Mar 2022 at 2:49pm
Doing a Sanden compressor conversion on my 8010.    Replacing everything,   I have become a little stumped on wiring the compressor.  The old A6 had a 2 pole plug, the new one has one green wire.  I'm using the high pressure switch at the compressor and the the low pressure at the drier.   Not sure how to wire from the A/C Switch.  is on side of the original plug the hot side?   Is it a good idea to put in a relay straight from the battery to the clutch?   I'm not the best at electrical stuff.  Tim
2-B's,CA,D15,D17,160,2-185's 8010
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 3:02pm
I use the AP Air kit 990-005 Switches mount at the compressor one wire to the first switch then the other wire on the switch goes to the other switch then to the compressor has all you need in the kit
This page was generated in 0.073 seconds.
