AC 5040
Chris R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris R Quote  Post ReplyReply Direct Link To This Post Topic: AC 5040
    Posted: 03 Sep 2019 at 7:52pm
what is a  AC 5040 that runs ok but looks a little on the bad side and are they any good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 7:57pm
what is a fair price
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 8:04pm
2500
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 8:23pm
What do you mean by 'a little on the bad side'? Pretty good little tractors if they are operating OK. 6 speed isn't as nice as the 8 speed in the late 5040 and 5050.5040 is about the same tractor as the Long 445 and the Oliver 1265.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 8:56pm
Tough little 40hp tractor.  PS is one-finger.
Yes, the 6-speed is bit cumbersome to shift, because the lever end and gates are sloppily made. But, having the upper 2 gears synchronized helps offset that a little.
Front end is made heavy.  Handles a loader well with factory live pump that's mounted above the PTO.  2-stage clutch.  3-pt is made well too.
If the composite (?) front grill is damaged, you'll play heck trying to find a good replacement.  If you're good at fiberglass, maybe not a problem.
Agree with Doug,  $2500....... depending on condition of course.
Edited by Gatz in NE - 03 Sep 2019 at 8:57pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 11:03pm
Got one up here on CL that fits the description.  Wants $4000 for it and has a few minor fixums.  It is the one with more gears.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 6:35am
If it goes,whoas , everything works and the sheet metal doesn't wave at you going down the road $2500.00 is fair. Pretty handy little tractors. Check out the shifting carefully. They do get sloppy. You gave to split it to change the forks.
Edited by exSW - 04 Sep 2019 at 6:36am
