Print Page | Close Window
AC 5040
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=164081
Printed Date: 17 Dec 2025 at 3:48am
Topic: AC 5040
Posted By: Chris R
Subject: AC 5040
Date Posted: 03 Sep 2019 at 7:52pm
what is a  AC 5040 that runs ok but looks a little on the bad side and are they any good
Posted By: Chris R
Date Posted: 03 Sep 2019 at 7:57pm
what is a fair price
Posted By: DougG
Date Posted: 03 Sep 2019 at 8:04pm
2500
Posted By: Gary Burnett
Date Posted: 03 Sep 2019 at 8:23pm
What do you mean by 'a little on the bad side'? Pretty good little tractors if they are operating OK. 6 speed isn't as nice as the 8 speed in the late 5040 and 5050.5040 is about the same tractor as the Long 445 and the Oliver 1265.
Posted By: Gatz in NE
Date Posted: 03 Sep 2019 at 8:56pm
Tough little 40hp tractor.  PS is one-finger.
Yes, the 6-speed is bit cumbersome to shift, because the lever end and gates are sloppily made. But, having the upper 2 gears synchronized helps offset that a little.
Front end is made heavy.  Handles a loader well with factory live pump that's mounted above the PTO.  2-stage clutch.  3-pt is made well too.
If the composite (?) front grill is damaged, you'll play heck trying to find a good replacement.  If you're good at fiberglass, maybe not a problem.
Agree with Doug,  $2500....... depending on condition of course.
Posted By: john(MI)
Date Posted: 03 Sep 2019 at 11:03pm
Got one up here on CL that fits the description.  Wants $4000 for it and has a few minor fixums.  It is the one with more gears.
Posted By: exSW
Date Posted: 04 Sep 2019 at 6:35am
If it goes,whoas , everything works and the sheet metal doesn't wave at you going down the road $2500.00 is fair. Pretty handy little tractors. Check out the shifting carefully. They do get sloppy. You gave to split it to change the forks.
