AC 2 row planter
eccosten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eccosten Quote  Post ReplyReply Direct Link To This Post Topic: AC 2 row planter
    Posted: 11 Dec 2011 at 10:27am
I need help with my planter.  I just picked up an Allis 2 row planter.  I will post pictures shortly, but from what I can tell I need 2 leveling arms for the unit.  The arm that comes out to connect to the snap coupler on the tractor has a pin going across the front that is spring loaded.  2 pieces of metal run parallel to the tractor and the pin is going across these pieces.  I attempted to hook up the planter, but the bars are too short.  How do I properly modify the planter to fit my D 10?  Thank you, Ean.
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 6:15am
Pictures would be great so that we could help you out.
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:31am
From your description, it could be a wc, wd hitch which would use the drawbar to complete.  Later Snap Coupler hitch eliminated the two piece with a one piece tongue, had better control of the planter and is a direct bolt on replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eccosten Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 2:33pm
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 5:20pm
you take the draw bar from your tractor and slide it in the track there is a place for a hitch pin and the front pin goes over your draw bar it will work with pin hitch or S/C eaither one .
