A Brand New 8050 With 7000Hrs
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: A Brand New 8050 With 7000Hrs
    Posted: 30 Apr 2017 at 6:22pm
It has had a slight miss for a while, but last night while planting around the farm, things got bad. So bad, that I was thinking I might be walking back to the house. I did get back and I wandered about the fuel filters. Changed them out, one at a time, and WOW! It acts brand new! Again. Who would have thunk it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 8:56pm
...so is that "change as needed" or regular scheduled maintainence?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:18pm
I guess changed as needed. LOL I really didn't feel to proud of myself when it was restarted after the second filter (water separator)was replaced. It must be plugged up tight. I need to do better.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 7:48am
Same thing happened to my 8070 this spring chisel plowing. I'm thinking it was poor fuel cause the filters only had about a hundred hours on them. Both combines acted up last fall too and I know the filter on the L3 was changed recently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:25pm
Stay away from biodiesel and all your fuel system will thank you.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 11:10pm
Have run bio diesel since it came out 11% blend, have never had any issues. I guess l am lucky. My 305 died the other day going thru the field.    completely out of fuel !!!! Filled all 3 filters pumped the hand pump, started on a quarter turn. That is Luck. By the way, my fuel gauge isn't working 😀
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 7:11am
Water will clog a filter. So will algae. My experience is that algae grows in bio diesel much faster than it grows in regular diesel. Once you get that stuff in your storage tank you'll pay 7734 to get it out. Algaecides will kill it, but they won't remove the dead plants.
