8070 shift cable high low and park?
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Topic: 8070 shift cable high low and park?
    Posted: 26 Nov 2011 at 9:25am
the shift cable broke on our 8070 what is the best way to get at where it hook up to the trans under the cab. Is there a acsess panal under the seat? also any other tips would be great thanks ben~!
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:26am
for got to say that it is the cable for the high low and park lever~!!
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:52am
Yes, take seat out, remove floor mat and access panel under seat.  Easy to do.  Make sure you have ends adjusted correctly so it shifts easily before covering everything up again.
The innovators offer what others will imitate.
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:02am
i don't know about the 8070 but some earlyer modules the entire cab could lift off and and you could get to it. with your type i don't know i hope you get it fixed
There are no atheist in foxholes.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:23pm
Could be the cable anchor. Much easer on 80 series than 70 series.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:41pm
got it fixed thanks for the help~!!
