8070 Allis block heater
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Allis block heater
    Posted: 05 Feb 2021 at 11:48am
The block heater on my 8070 doesn't seem to last as long as I think it should.  I seem to have to replace it every couple years and really need every year. A new one will warm tractor up in an hour to start.  After a year, it takes 4 hrs for it to start easily in very cold temps. Tractor stays in unheated shed.  This is my loader tractor and need to load round bales for the cows once a week and push snow.  I would like to put a tank heater heater on it, but don't see a port in the block i can take out for the inlet to a tank heater.  Hard to see with loader on also.  If it is complicated, I'll just put in the original type of heather with a new cord again.  Heater still works on it, but like this weekend, I'll need to run it and will have to be plugged in for about 4 hrs to get it to run with it being below zero.  It will start without being plugged in at about 30 degrees F.  I just seem to have better luck with a tank heater on the other tractors.  I am also using a heavy duty cord to plug in and unplug before I start it. I only plug it in when I need the use the tractor.   So am I missing a plug somewhere on the block to take out and install a nipple. Thanks Greg
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 2:02pm
Some tee in under (6" lower) the AC compressor. I think there is a block drain there?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 3:28pm
Thanks, I'll have to take the loader off and look. I'll have to take it off anyway to replace the heater that is on there. I can't get the side panels off with the loader on.  Not a big deal to get loader off except it will be below zero this weekend and snowing. Maybe I can see with the hood still on.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 11:59am
I have an 8030 with  a tank type heater on it, should be the same I would think, if you pm me and email or cell that accepts picture I can send you pictures of where my 8030 is plumbed
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 3:47pm
Are you unplugging before starting? if not, that is why you are going through heaters so quick.
Where are you sourcing the new ones?
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 6:42pm
First post says unplugged before starting.....
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 6:57pm
Ok, dumb question...
Why unplug the heater before starting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:28pm
I dunno but that's what Kats heaters instructions say. Maybe flowing water is detrimental?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:32pm
Or the heating element hates vibrations of the engine when plugged in. Kind of like using a 60 amp household lite bulb in a shop trouble light. One little bump and POOOF !!
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:32pm
The sudden change in water temp on the hot element shocks the element and can cause small fractures in the outer case shortening the life of the element. Thats what Kats told me when they denied 2 warranty claims
Edited by Boss Man - 07 Feb 2021 at 7:33pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:53pm
I’ve read having air pockets going past them causes them to fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 9:26pm
Sounds plausible....have been guilty of doing that a few times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 6:06am
re: Why unplug the heater before starting?
cause your extension cord isn't 23 acres LONG ?????
really, it's that simple..
consider ...
it's still plugged in, you hop on, tractor starts easy(even in witchesteet weather...),animals are HUNGRY, got LOTS to do, you FORGET the heater's still plugged in and  away you go.......
...so does the extension cord and possibly the heater rips out,cause the 2 tyraps didn't really SECURE the power cord to the tractor..... the trail of antifreeze 'reminds' you ...hmmm I was supposed to do something.......
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 6:39am
Ok that really was my first thought but also thought surely that's not the real reason. And yes, I called you Shirley
This page was generated in 0.049 seconds.
