8050 |
randy ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1218 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2014 at 9:32am |
My 8050 makes a noise in the hyd when the 3 point hitch lever is all the way up with the mower is raised. If I move the lever down a little it quits. Sounds like it is against a relief valve. I am going to put a gauge in the system to check stand by pressure later today. Any ideas what it could be?
Thanks, Randy |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21902 |
Adjust/lengthen the cable to the 3-point valve. It should NOT come 100% to the top....only 99%.
Thanks, I will try that. Once again Thanks
