8010 wont go into 6 the gear... |
cotncrzy ![]() Orange Level ![]() Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jun 2015 at 2:57pm |
My 8010 wont go into 6th gear, 5th is hard. Still goes into reverse fine. Cant see anything obvious behind batteries, nothing loose, etc. It was fine and just all at once wouldn't go... Shifter is in the gear it represents, in other words it not bottoming out in slot. It is in the gear it shows.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Johnwilson_osf ![]() Orange Level ![]() Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 941 |
I am assuming this is a Powershift model. Sounds to me like the shift cable has come out of its hold downs under the cab. Pretty easy fix.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5598 |
A zip tie broke inside the console.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21909 |
If the clutch pedal isn't coming all the way up, you'll have that. Also, the clutch pedal cable could be the issue.
